hi my name his Luke , iam from Montreal quebec canada ,
new user on here , iam a skyline enthousias since 4 year , ive went trew alot of build , and this is my BABY BLUE GTR
Moteur:Swap r34 2000 20 000km
HKS T4 DIVIDED MANIFOLD (CAME FROM A T51R KIT)
HKS 60 MM WASTE GATE (1 BAR SPRING)
Precision 62-66 DUal ceramic baal bering
CUSTOM 3.5 inch Stainless downpipe
CUstom bit of a piping after the turbo
CUSTOM OIL LINE
Apexi complete cat back*
Greedy type r BOV
Tomei head gasket 1.2 mm 87 bore
Tomei timing belt
TOMEI OIL PUMP
Tomei oil pan baffle
Tomei TYPE b camshaft
Tomei cam gears
N1 water pump
ACL main berings
ACL ROD berings
ARP rod bolts
ARP HEADSTUD
Spool oil drain kit
Yellow jacket coil pack
Hks intake wit custom pipe*
Nismo engine mount
Cusco OIL catch can 3 liter wit stainless steel braided line
Drivetrain:
Cusco type RS 1 WAY FRONT LSD
Cusco type RS 1.5 WAY REAR LSD
R34 6speed getrag (20 000 km)
1 piece allu driveshaft (driveshaftshop)
Nismo twin plate competition model
Nismo r34 tranny mount
Nismo r34 stainlesssteel clutch line
Fuel system:
1000 cc denso injectors
Greddy twin entry fuel rail
Sard fuel pressure regulator
Twin INTANK OEM GTR fuel pump 800hp+
Cooling system:
hks piping kit*
Arc 4 inch intercooler
Mishimito radiator
Nismo low temperature thermostat
Trust greedy oil cooler wit filter relocaliser
Ecu:*
Haltech platinum pro WIT every damn sensor u can think of , racepack dash display
Braking stuff
R34 brembo wit project mu brake pad
Stainless steel braided line
Suspension :
cusco type zero 1 coil over kit
Ams hicas delete kit
Ams front upper table
Ams tension rod
Ams rear Camber ajuster
Ams Inner + outer tie rod
4x new front balljoin
Roller:*
17x9 +15 offset work rsz-r*
275-40-17 g force kw2 tire*
Drag wheel*
17x9 r33 GTR
275-40-17 mickey thompson drag street ET
Interior:
Haltech RACEPACK DASH DISPLAY . FITTED in the oem stock cluster , yes front torke and fuel gauge still works , CUStom made
cusco 7 pooint rool cage*
Nismo gt500 6mt shiftnknob 12mm
Recaro sr4 blue*
Bride low position seat rails
Alpine radio*
Razo foot pedal
Sard battery relocator kit /sard box
Exterior
N1 Headlight
Nismo front bumber
Nismo side skirt
Nismo rear valence
Fluids:*
Tranny;Motul 300 gear oil api-gl4 75w90
Nissan matic d transfer case
Front diff+ rear diff
Motul 300 gear oil 75w90
Engine:
Motul 15w50
Oem oil filter
here a video of my car idling , just had installed the new Precision turbo , and new 3.5 inch down pipe
hope u guyz enjoy
i had dynoed 616.9 whp last time wit my OLD turbo S362 DOUBLE BATMOWHEEL bullseyes turbo , this was at 22-23 psi
still on STOCK PISTON n stock rods :P
eevrything is the same except , better oil pump now and new precision turbo and new downpipe
cant wait tooo go back on the dyno but RIGHT now its the f**king winter :(
Edited by Lucky LUke
How do you find the Tein Mono's? What's the comfort level like on the street?
Done much track time with them...? Is that 13kg front springs and 11kg rear...interesting
Nice! Was stuck between choosing a 6262 and a 6266, ended up going a 6262 so will be interesting to see your results :)
Wat kind of setup u got ? ,
could u post dyno sheet? or wait ill go chek your build tread , but if u want u can post it here no prob;)
i just got them 2 days ago and installed them , yes the spring rate his 13 F and 11 R
and i will maybe go track them but my car his more of a drag car wit the last turbo i had , now wit this smaller presicion well see wat kind of lag i get , if i dont lag too much for sure ill go lapping day :)
tx for watching boyz!
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
