Has anyone got any 32 GTR dash vents? i need the left one and the center one... As mine have both fallen apart. Also how hard is it to replace the dash in the GTR? is it an easy one or is it pull almost everything out of the car?
thanks
https://www.sau.com.au/forums/topic/414854-r32-gtr-dash-vents/
I TRUST YOU RICHARD! I'm Just looking at my options atm.. I have NO money due to this rebuild breaking my balls. But when i get the car back and have a bit more moneys i want to fix the A/C and the bubbled dash. When those are done im all good... Interior wise i have 1 small bubble and the cracked vents. All seats look new.
Oh also need to replace the ECU... Verms needs to hurry up and sell me his Apexi.
hey mate It can be done without taking the dash out if your vents are already broken you can remove them with the dash still in place, just be very careful when putting the new ones in :)
ignore that if you are planning to replace your dash just do the vents then :)
Thanks mate yeah thats why i was thinking if its hard to take the dash out ill wait till my motorbike will be back up and running as when the car is back ill be taking the bike off the road to do a full respray haha. Hence my thoughts where just to get new vents and take them back out when i replace the dash. Still deciding.
Its more waiting for you to give me $$$ for it!
  • 4 weeks later...
Yeah - if your replacing old and there broken you can pull them out and just push the new ones in.
But be aware that the vents are screwed on from the back of the dash
Hey fellas just trying to put in a new centre vent in my 32... but it doesn't want to push in from the front even with a bit of force
Sinista, what do you mean that they are screwed in from the back? I can't see any screws in the new vent? or is there a bracket that screws into the dash from the back that holds in the vent?
Can i get it in from the front without removing the dash? is there some sort of technique that'll help?
I read somewhere else on the forums someone said "look inside them and you will see tabs which you put a flat screwdriver into and lever down. Its a lot eaiser than taking the dash out."
any help appreciated. cheers
My centre vent fell apart yesterday.. finally... they have tabs ontop and underneath them. but since mine was apart i could just pull it out, bit of glue for not and shoved it back in haha
Sorry about not sending Pics. Hit the turps early otaday and just got home.
EWill do it tomoz.
Edit: And Anthony when wouold you like the Dash for cash ?
Will have another available soon. Because my brand spanker is turning up mid to late Jan :D
well i need to see how i am with cash after the ECU, Injectors, boost controller and tune are done. if im all g ill grab it off you then... whats the go with those ID injectors you have?
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
