Nothing yet, had 5 different auto electricians come to my mechanic and none of them know, dont wanna know since its an import. Been to busy at work to chase this up christmas rush is killing us. Only update now is engine light wont turn on fuel tank doesnt prime so no spark at all. Gonna do a search now for stagea electric info and english version for the fuse box.
That sounds like ur losing 12v to the ecu when cranking, if ur ecu isn't getting power then u won't get the fuel pump to prime, u'll get no spark or injector pulse.
Yeah computer died, tuner replaced it and car started straight away but he reckons what your saying something shorting it and it may happen again. Any ideas on what to directly check for as cpu is now not covered by warranty if this happens again
Glad to see u got ur car going again, as for what's causing it there are many possibilities, bad earth is a common cause of things shorting out, broken wires, have u done anything electrical to the car lately? Install something ,remove something? Make sure that the connection to the computer is on properly and the bolt done up, check all connector to igniter,coils may ect. Make sure battery terminals are tight and in good order. Also make sure u have the correct fuse amp fuses in the fuse box, someone may have put a higher amp fuse in there cause they had nothing else, if my memory serves me correctly its 10a for the ecu. Good luck with it, hope for ur sake it don't happen again. Where bouts u located?
Sydney. Nah the only thing electrical done to the car was get tuner to put ecu with nistune map on it and z32 afm. My original computer is now back on with the same nistune map installed and same tune, cas was also swapped as that was burnt out. Car is running really well now just picked it up and took it for a quick spin. Will look over everything shortly and make sure nothing else is loose, it has been looked over though quite a few times. Thanks for all the help
