parting out my r32 gtr race car
gtr gearbox with osgiken gearset+sandwich plate nismo short shifter all new bearing though out box installed when the os giken parts installed.gearbox has done very little work done 7 trackdays and in that time i have replaced oil 3 times. i have spent well over $7000 in parts alone
$5500
Alcon 380mm brake kit suit front has rotors,caliper,pads(fs2500)adapter plate will just fit under 18x10.5 rims direct bolt up nothing else needed. i have done 1 track day about 20laps of wakefeild park these are like new.these are the next level down from the v8 supercar brakes
$6000
K-sport 355mm rear brake kit comes with full conversion just bolt up i have done 7 track days with these pads in them have done 2 track days still in excellent condition
$1800
Bc coilovers ER series has the standard spring rates 10 front 8 rear these are the best bang for buck coilovers. i have managed to do a 1min.03.7sec around wakefeild and 1min.38.1 around eastern creek with this suspension i do recommend to go heavier spring rates to go faster.springs are $77 each if you want to upgraded.this have done 7 trackdays these are in perfect working order as well
$1200
Formula Ikeya front and rear fully adjustable arms these have done 7 trackdays no crashes no kerb hitting are in perfect shape both are the lower control arms for front and rear
$1800
Defi guages oil pressure,oil temp,water temp,boost up to 2bar and unit with all connections all mounted on a plate that sits where the aircon and radio sit
$1300
will have more parts for sale at a later date
only selling car to convert back to a road car i have driven car 7 times in 3 years
want to enjoy car a little more
https://www.sau.com.au/forums/topic/414857-gtr-high-performance-parts/
$5500 now $5000
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
