Part:Rb 25 NEO engine cover
Condition:used
Description:plastic one that covers your rocker covers
Contact Details:as above
Asking Price:50 ono
Pick-up/Postage Arrangements:pick up preferred but willing to post at buyers expense
Other Comments:comes with the bracket and fittings
Item 5
Part:R31/HR31 custom car bra
Condition:used but very good
Description:soft inner lining to protect your headlights, grill, fr bar and bonnet from stone chips
Asking Price:$250 ono
Other Comments:used on my passage for about 6 months. Wont fit my GTS2 or the bar on my coupe.
Part:hr31 coupe drivers side rear quarter panel
Condition:very good
Description: I cut this panel off a coupe I wrecked a few years ago, left more on it than required as I knew it wouldn't be used for a while and the edges would rust
Contact Details:text me on 0415983939 as I don't get much mobile reception here
Asking Price:250ono
Pick-up/Postage Arrangements:pick up only. Will send but courier must be organized by buyer
Part:forged rb20det redtop
Condition:good/used
Description:removed head and sump to have a good look, sump is back on but I don't want to put the head back on with used head studs. complete from covers to dump pipe. turbo has an adjustable actuator and minimal shaft play, have 2 inlet manifolds with it and a vrs gasket which is just missing the exhaust gasket. so it needs head studs, exhaust gasket and a few welsh plugs as I didn't have enough of them to replace them all I also have an ecu and loom but cant guarantee they will work or that the loom is complete. the block is currently in the passage shell if you want them both I'll work out a cheaper deal
Contact Details:text me on 0415983939 as I don't get much reception here
Asking Price:$500 ono
Part:series 1 passage rolling shell
Condition:average, reasonably straight
Description:was my daily until march this year has qld mod plates for a 25/30 and another one for 2 racing seats, custom interior. series 3 front off a coupe no headlights but it does have afterburners and matching garnish
Asking Price:$1100ono
Pick-up/Postage Arrangements:pick up only but I have a car trailer you can borrow if its local and if you have a tow vehicle suitable
Part:Greddy T88 33D turbo
Condition:needs rebuild
Description:bought for my coupe but cant afford the rebuild (quoted $1281 from Mr Turbo to rebuild to standard or 1400 to rebuild to handle more with his custom billet wheels)
Asking Price:$500ono if I get close to the asking price I'll throw in a trust heat shield to suit (test fitted but never used on running engine)
Pick-up/Postage Arrangements: pick up or will post at buyers expense
Part:coupe front seats
Condition: used but, air lumbar was still working when they were removed
Description:drivers side missing its rail
Asking Price: 90 ono
Part:rb25 factory manifold modified to suit external gate turbo
Condition:used/modified
Description:factory exhaust manifold changed to suit t4 flanged turbo and has a v-band flange for 32mm garrett external gate. includes gate & dump pipe
Asking Price:$280ono
Pick-up/Postage Arrangements:pick up or will post at buyers expense
Part:2 door c pillar trims
Condition:good
Description:perfect for a coupe with a cage and no rear seat as these don't have the seat belt holes in them
Asking Price:60 ono
Part: hr31 2dr mirrors
Condition:good
Description:I have 1 pair of fold in mirrors off a coupe and a single non fold in (I'll have to check what side it is)
Asking Price:60 for the pair of fold in ones and 20 for the non folding one
Part:passage c pillar trims
Condition:average
Description:they are the furry ones but I would remove it as the fur isn't in the best condition
Asking Price:$40
Part:2dr headliner non sunroof
Condition:very good
Description:ah, lines the roof
Asking Price:40
Part:veilside steering wheel & horn pad
Condition: the leather is starting to crack
Description:not for someone building a show car unless you get it re-trimmed, they were 300 new and are discontinued. I have seen them sell for as much as 477 us when the exchange rate was bad
Asking Price:120 ono
Part:veilside shift knob
Condition:good/used
Description:comes with attachments to suit most vehicle shifter threads
Asking Price:60 ono
Part:HKS mushroom pod and alloy adaptor(rb25)
Condition:used but good selling as it doesn't fit the q45 afm it suits an rb25
Description:the neck is huge, the filter fits directly onto the front of a greddy T88 turbo
Asking Price:50 for both ono
Part:minature car/go kart
Condition:frame is rusted but is only made from angle steel, fibreglass is pretty good just needs a few crack repairs
Description:I think its a rear engine 50cc honda and has a 2spd box, needs new wirirng. comes with some of the parts like 1 headlight, indicators 12 inch wheels tyres are dry and cracked from sitting for too long. I have never seen one before and cant find anything like it on the net it has 50's/60's body style and there is 1 brake rotor on the rear axle
Asking Price:300ono
Pick-up/Postage Arrangements:pick up only. will fit in a 7x5 trailer
Part:xf falcon panelvan
Condition: body poor, engine & all windows good
Description:more rust in it than I was expecting, suit parts or resto. all glass is good, only needs a battery to run. runs on gas and runs well
Asking Price:300 ono
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
