For Sale is one used HKS Single Turbo kit to suit Z33, but also fits V35 and PM/PNM35
VQ35de motor only.
Location- Sydney NSW
This is the HKS picture of the Kit.
This is how it sits on the motor.
This Kit should be well known to Z and V drivers, there are a few cars getting around with them now, so they are a proven kit.
It consists of:
  • GT3037 HKS ball bearing turbo 56T 1.12 rear - watercooled.
  • HKS GT II 60mm external gate
  • Exhaust manifolds, incl cross over pipe
  • HKS high flow cat converter
  • Intercooler
  • ALL piping from air filter to cat converter incl clamps and silicone joints
I have had this kit installed on my PNM35 stagea for the last 11 months. In that time it has done less than 10,000kms, including two trips to Goulburn for car events, one night (3 runs) at WSID, and basically taking my Mrs to and from work. So it has not done a lot of work. No track days. Boost has not been above 6psi, which for this turbo is tiny. Original markings are still visible on the turbo wheels. There are a few scratches on some of the pipes from installing however they are no really visible once installed. ALWAYS warmed up before use. Turbo doesn't have shaft play or anything a flogged out old turbo would have.
The Kit also comes with extras incl injectors, fuel pump, Uprev MAF, and Boost Tee which I will detail later.
I have modified 3 parts of the kit to fit my car:
1) I do not have the sump that came with the kit - it does not fit the AWD motor so I sold it off. I modified my existing sump to accept the oil return. The buyer has two options - do the same, modify the existing sump pan (which you will receive as a template) OR buy a pan spacer from the US that has a place for a fitting in the side for an oil return. They are easy to get and not very costly ($150)
2) I had the pipe from the turbo to the intercooler modified to suit AWD, as the original one fouled the front driveshaft. While I am pretty sure it will still bolt up to a RWD car, I would have the pipe modified to create better airflow, as the rwd have more space in that area
3) I had the exhaust modified to clear the AWD transfer case. The over all length is exactly the same, however I just had a fabricator insert about a 200mm piece to allow the bend to be more rearwards- you can see this in the photo. The Cat was attached to this pipe. Again - I'm pretty sure it will bolt straight up to the RWD cars, however its not a big job for an exhaust place to modify it if it doesn't.
I will also include:
  • A Set of 6 Deatschwerks (denso) 600cc injectors (plug in for VQ35de) including original flow report. RRP $580
  • An Uprev GT AFM - this re manufactured MAF allows the ECU to read higher levels of boost. If you want to turn the boost up from the gate pressure (4.5psi) you will need a larger AFM. RRP $350
  • A genuine Walbro GSS432 255lph drop in fuel pump in original package RRP$130
  • Turbosmart Boost Tee to adjust boost levels.
So basically all the new owner will need will be an ECU for the kit, which I can point you in the right direction to Uprev or you can source your own.
I will ship at buyers expense - however understand its heavy, large, and there are fragile components. I will do my best to package them if you want it shipping, but I can't be certain it will arrive perfectly. I have only a few of the original boxes.
If you want to have a look at the kit, thats fine. Let me know.
Any questions I will try to answer. Best way to contact me is through PM on the forums I won't always answer my phone - 0431 090-240
I will NOT hold the kit for you, unless you leave a non-refundable deposit. Please sort your money before saying you'll take it. Don't lowball- go and ask a shop for a quote to Turbo your car.
PRICE- $3750 firm.
Stop wasting time on NA mods - this will beat all of them hands down.
Photos to come.
I should also say that the parts in this will bolt on to a VQ25DET, and provide you with the basis for a good powerful car with Ext gate. You'd need to change the rear housing to .83 from 1.12 otherwise it'll be lag city, but I'm just putting it out there.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
