Hi guys,
Was thinking of running these tires as a cost effective measure over a season.......
Medium compound and Virtually brand new x 4 $1200
Some good reviews on the forums but decided to go a different direction. Ran maybe 6 laps and to be honest if i didn't say they were used you couldn't tell.
http://www.federaltire.com/en/products_detail.php?class=Federal-Motorsports&products_detail_sn=3
:cheers:
https://www.sau.com.au/forums/topic/414925-federal-fz-201-2853018/
  • 3 weeks later...
    • So there is no other way to remove and install the ball joints then to buy the Frenchys kit?
    • Just to close off this post with the cause of my oil consumption issues. Vertical scoring and glazing at the bottom of cylinder 6. I'm not happy, but at least I finally found something. I'll pull it and get it apart asap. Hopefully I don't need to go one size up in piston.
    • I finally got around to purchasing an actual articulating borescope. Great tool to have, I've been very impressed vs my old regular inspection camera.  With that being said, sadly I finally found the cause for my oil consumption. I always had the feeling something wasn't right but compression and leak down tests were always perfect and I had already inspected the cylinders. This time i dropped each cylinder to its absolute lowest point and with the better quality camera I found this... Bottom of cylinder 6.  Scoring looks deep and I'm presuming oil getting by caused the glazing. I already spoke with my assembler, and will be dropping it off as soon as I can pull the motor and get it apart. I'm just hoping it's not deep enough to require boring out from 86.5 ->87mm. Pistons aren't cheap.
    • I think it's the same. It all comes from the same shithole refinieries in SE Asia.
    • I was referring to the final octane level achieved once 10% ratio of ethanol is added.
