hey guys,
I am thinking about giving my brembos a freshen up. They've copped a few stone chips over time, and since I put the 17's on which clear them by about 1mm one of them must have got scraped either during installation of wheels or through some flex under load.
They are currently the OEM Gold colour - I have some touch up paint in the mean time - but it's not a perfect match as you can't buy Brembo gold anywhere. So i'm thinking of doing a complete colour change.
What do you think would look best on a white car with flat gunmetal grey rims? I want something that will 'pop' - so silvers, greys and golds are kinda out.
Here are some options I like - comments welcome - but any suggestions for other colours would be good too.
Candy Blue
Metalcast Anodized Red (did this colour before - looks ok but bit 'played out' IMO).
Pearl Orange
Metallic Teal
Kermit Green
Tiffany Blue
https://www.sau.com.au/forums/topic/414935-what-colour-to-paint-brembos/
Yeh - I like the grreen too. But it's got to be right. I have seen an EVO with Ford Focus RS iridiescent green on it, looks amazing, but it's a tri-color paint that needs to be done profesionally - I need something out of a can. VHT does Kermit Green though, and I reckon with a white or silver base coat it would get some nice colour.
No - no purple. There will be no purple lol. Or hot pink.
I was just thinking about colour change to my Brembo's last night.. hmm.
I like the idea of black with white brembo stickers. That green does look nice though and it's different.
thats what ill be doing.. knowing that the stock evo ones fade, is there much point in going red again??
although I really like that anodised red up there!!
I think the EVO brakes fade when they've had a hard life. Even if you resprayed properly, regardless of colour, I reckon 5 years would be an expected lifespan for them to stay looking fresh before you needed to re-do them - but hey - probably time for a colour change anyway!
The anodized red does look nice. I used MetalCast Duplicolor - it's a two stage system, metallicf silve basecoat then the red candy top coat - you can vary the depth of the colour by the amount of layers you do. Pics on my Stagea:
I think the Teal blue looks awesome though.......matched to gold rotor top hats and gold lug nuts?
Update: the metallic teal is powdercoat. I can't really be shagged removing the calipers, dissasembling them and sending them away for powdercoating. Even though it looks awesome, and would be very durable.
VHT does a colour called Torque 'n' Teal - which is close, but doesn't have metallic in it. Might buy some and do some test painting on something metal to see how it comes out.
Edited by SMOKEYC34
I have to get mine sprayed soon due to changing the rotors... leave my dad for one minute and big chunk of paint is off the fron caliper... Massive fan of the candy blue. However, mine are going the purple with white decal. How much do they ballpark for?
yeh i might hit you up for some exact names mid december, the candy red would match the DB5000 alloy hats I have on..
but i was thinking a pot belly black, which is a satin black and again durable as fark! and being satin, brake dust might not be so noticable lol
I'll grab some teal paint after work today - do a test run.
But also maybe spearmint would look cool.
Had a vision that it would look good, especially with some small highlights to tie it in to the rest of the car.
An interesting thing for people reading this thread in the future, I've done a lot of reading and it is widely written that you don't have to use high temp paint for the calipers UNLESS you track your car. I have always used high temp paint and it is frustrating how few colours are available. But people have tried and tested street driven cars with just a conventional paint and confirmed a street driven car won't generate the temperatures that will bubble the paint. This means you can use any off the shelf paint - which increases your colour options about a million times over.
Another method is to put down a basecoat of white high temp paint, go over with your choice of any conventional colour, and seal the decals on with high temp clear. I would at least recommend high temp clear, as i've seen conventional clear coats go yellow on wheels before - so assume same would happen to brakes.
I also like the purple Josh put up!
yeh definitely can't be a rushed job - or else you will be doing it again in no time.
I am starting to think I will need to take the calipers off if I want to get a job done that i'm happy with- if only I could get a set of 'exchange' Brembos that didn't cost a ballsack - I could paint them and swap them on in a couple of hours.
That purple paint is most definitely Duplicolor Metalcast Purple. You can buy it a SuperCheap Auto - costs about $20 a can, and you have to buy the primer - also about $20 a can. You only need one of each to do a set of 4 calipers.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
