you are using brembo decals correct?
are you going to clear coat over them? wondering if the stickers will fall off without a decent clear..
Yep - going to buy a bunch of decals in diff colours to see what works best. Then VHT high temp clear over top. Doubt they'd fall off but they might be a bit more durable against things like wheel cleaner and high pressure hoses.
Mat how painting the brembos going? Keen to see some pics! I might have to go this direction, very temtping but i love the gold too much
Not even started mate - I'd like to get the job done over xmas. But the trouble is I live at a body corporate controlled apartment building which says no car work in the garage - i do small bits n pieces but things like cars on axle stands etc would be pushing it. I usually do work at my parents place in their garage, but they've since painted the floor and made it look schmick - and then told me i'm banned from there :closedeyes:
So i'm not sure exactly when this will get done.
I did a bit of research after asking, apparently the VHT clear will make the brembo stickers go yellow in a few weeks :yucky:
a few of the evo guys said dont clear coat, just stick them. hit a couple of hard braking corners, and they will cake(literally melt) onto the calipers..
a few have tested with industrial hi pressure hoses, and still didnt come off lol
excellent bit of info - thanks aaron.
This man does things well...
http://www.ozfoz.com...&st=0&sk=t&sd=a
Gets wraps for all his wk. (incl courier). User Name on OzFoz = "CRUISN"
Cheery Terry - i did come across his thread when i was searching for color pics. The polished Brembos look AMAZING - but I think even he said so himself that he'd never do another set again haha.
I don't mind doing the work - it's more the logistics of getting the brakes off, dumping the fluids, and re-bleeding when I don't have a permanent garage space that would allow me to do so.
I'm motivated though - this will happen eventually - but I think i might wait for my rims to arrive so i can see the colour with my own eyes - might help me chose the brake caliper colour.
I had a thought Mat, what about sort of a glossy gun metal grey with white brembo stickers? i think that would look nice depending on the colour of wheels but if your after something to stand out it wouldn't be the best idea.
yeh im thinking of doing that or black with white..
dont like the whole brakes that scream look at me, and red will just go pink again
Didn't you drive a fanta orange S15?! :action-smiley-069:
And yeh - not gunmetal.
Brembos deserve some attention!
Just bought BC Coilovers.....so looks like a 'wheels off and car on stands' day in the garage will be happening regardless. Might be a good time to paint.
Red = +15kw
Why not just get the eBay stick on things?
I've heard they don't melt at the track at all.....
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
