HI all,
So i just recently got a second hand engine installed after i blew my last one up..
all is well except for this really annoying cough/splutter on a cold start just off idle...
if you try and put any load on the engine when it is cold (around 1000rpm) it will cough and splutter to the point of stalling.
i recorded a video so you will know what im on about:
i have replaced:
Leads (top gun)
plugs (NGK)
Air Regulator (off another motor)
i also took the injectors, fuel rail and afm off my old motor which had no issues and it still does it.
if its worth mentioning:
1. Car is a manual conversion (never had issues before)
2. all is fine when it is warm
3. it seems to idle a lil low when cold(around 800 - 900rpm, could be more or less as i have a sticky tacho), but a little high (1100 rpm when warmed up)
https://www.sau.com.au/forums/topic/414953-r31-rb30e-cold-start-issue/
I'm not sure how R31 ecus work, in a R32 and beyond I would suspect the coolant temp sensor (not the one that feeds the dash cluster, the one that feeds the ECU), when not functioning it might not be going into the cold start map (richer than the normal one).
i had issues similar to this an adjustment to the TPS cleared it up
so i have tried so far:
1, Spraying crc contact cleaner on the AAC Connector, Both sides of the coil, Air Reg connectors, tps connector......
2. tried having a play around with the tps, fully clockwise it idled lower, didnt fix the issue with the spluttering..fully anti clockwise the issue wasnt any better but it idled higher
3. unplugged afm and it idled like shit, wouldnt rev etc so i know the afm works.
im baffled as to what it is
if its not that then keep trying other similar things, 31s are getting old now and most of them have had the tits revved out of them by p platers and messed around with a lot
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
