I have an '82 Laser you can use. The choke is stuck open, so you have 7-8 seconds of turnover to start the car with a sequence of throttle pumps before fuel floods the block. If this does happen, you will need to remove the spark plugs and drain the bores with the hose in the glove compartment, else wait ~45 minutes for it to evaporate/drain through the piston rings. I'd strongly advise you to pull over before a hill so the transmission can reset back to 1st, as the kickdown switch doesn't work and rolling backwards down a hill in 3rd can be problematic. Passenger door hinge is broken, so you will need to let your dance partners in through the drivers side by folding the seat forward DO NOT MARK MY VINYL UPHOLSTERY. One rear passenger will need to hold their seatbelt in place or loop it around the other passenger's seatbelt. Do not use the sunroof, it opens but does not close, don't ask me how I know this.
Bring it back with a tank of super and If I see one scratch on it...
I can take you and up to two others in my 1991 VP executive. It is equipped with the legendary Buick 3.8L v6, a motor that has stood the test of time for longer than you've been playing World Of Warcraft. One of the coil packs fell off and I haven't bothered to re fit it, as the lumpy idle sounds attractive to the opposite sex.
The paint job could be described as needing a bit of work, though I like to think that it has character. It is GMH purple with a hint of undercoat peeking through in various spots on the car. If you squint, you'll be in awe of the car. It looks like a midnight sky on a crystal clear night with mesmerising galaxies glistening back at you, especially on the roof where the majority of sun damage is.
One tail light is faded, while the other is an altezza item from eBay. It reminds me of how you youngin's get around with one shoe lace a different colour than the other, so I'm sure it will be a hit with your peers.
Speaking of hit, the front quarter panel on the drivers side has suffered a minor bump. The indicator now hangs elegantly from its loom, giving it a hint of swag.
Unlike birds, I won't care how much of a mess you make in the back seat, as this car was previously owned by a single mother of 6 children and hasn't been cleaned since. You'll feel as if you're at one with nature with various animals rummaging around through the piles of megoreng and twisty packets, just like your local park. This will seal the deal with your date, as bitches love getting back to nature.
Given the short notice and the quality of my "whip" as you whipper snappers would call it, I would expect some form of payment greater than what a regular Nissan owner would receive. If I could attend the formal and the after party with you and you agreed to pay for a tank of gas, beer and food for the night, then I am prepared to make your formal an unforgettable memory that you will treasure forever.
Edited by kawasakirider
FARKING LOL :rofl2:
O/T but cant you just hold the throttle wide open for a min to dry the fuel, or do cars not work the same as bikes
I got a camry owned by "lady owner".
U won't feel cool while you are getting beaten at the lights by your fully sick mates, however while they are getting pulled over by the cop & getting bum rapped for hooning you can speed past them while the cops won't even take a 2nd notice*^
*tested by me & it seem to work, I overtook a bunch of granny cars doing doing about 15k over the limit, went past a police car approaching the opposite direction & he did nothing.
^Disclaimer: Does not work against reveune cameras.
Edited by Mayuri Krab
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
