Ive generally used the specified weight to determine what a car weighs, but i was wondering if there is somewhere you can actually get your car weighed properly?
First that comes to mind is just going to a council dump where you drive up onto the weigh bridge :wassup: then just subtract your weight from the cars
Considering this is like $10 ide say it would be the cheapest, and im fairly sure its accurate to 1 KG
https://www.sau.com.au/forums/topic/41498-how-to-weigh-your-car/
Most accurate way would be too take it to a susp place as they have coner weight scales to measure the weight under each individual wheel (All 4 are measures at once though)
Weigh bridges are calibrated in 15kg / 20 / 25 / 50 kg increments...whatever it is they arent accurate if you want to know plus/minus 5kg
When i rego'ed my car in NSW i just took it to a chicken farm and had it weighed there and the RTA was ok with that. It put me in a lower rego bracket than that stated by the RTA too.
The 33 came in at 1350 and cost 2 VB tallies to weigh.
-rb25
was that with you in the car?
I think r33 are a little lighter than people think. Should be able to get it down to a flat 1300kg with a few basic removals (spare, back seat,sub, etc). Most actual readings i have seen have not been up around 1400kg as people make out.
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
