Hey guys, I've got a R34 GTT and it has a varex exhaust system on it, the kind that is supposed to close a butterfly within the cannon and make the exhaust quiet at the press of a button.
Anyways, i bought it with the exhaust already on the car, and the power for the box controlling the butterfly wasn't connected, so i couldn't test it out.
I connected everything up after buying it and as always, turns out it wasn't connected for a reason, the butterfly in the exhaust doesn't open or close when i use the remote.
Pretty much there is power from the battery going to a small black box which is placed in the boot. from that box another set of wires connect to the cannon end of the exhaust.
I've checked the battery on the remotes and everything and it still doesnt work.
Does anyone have any suggestions on things i should do or check?
Thanks heaps guys
https://www.sau.com.au/forums/topic/415019-varex-exhaust-connection-question/
Might be a bit of a pain but can you put battery power directly on the motor for the butterfly. That will tell you for sure if its dead
X-force are pretty good to deal with and should help you out with replacement parts
Varex mufflers... pretty good exhausts. Not something that belongs in the same sentence. They've been reported to be restrictive even when the butterfly has been fully open, not to mention illegal anyway.
thanks callan, should i just take the two wires that go to the motor and connect them directly to the power? how will the butterfly know when to open and when it should close though?
moodles, they aren't illegal, thats what a lot of people believe though. im sure about this as i actually looked into it, and ive gotten this car through a check after getting a defect for noise pollution, and they let me through it with the varex exhaust when it was closed.
Email Varex and ask them for a replacement control box perhaps? It could be the remote too I guess.
Hooking direct power to the motor will fu*k it.
I've seen it done where voltage was applied to the motor to test it. Reverse the polarity makes it go the other way. This may have been done acoss the circuit board so not sure if it was full 12v
They are restrictive closed but not to bad when they are open. The one I saw wouldn't make full boost closed but open it was fine
It wont damage it. I was running mine through a switch in the dash for 6 month with frequent use and never had a single problem. Just hook the power wire power wire to one side and touch the negative on the other. If it moves then its not the motor if it doesnt try swapping the wires around. Still doesnt work it could be the remote or control unit. Does the light come on the remote when a button is pressed?
so do i use the control box at all? or do i cut the wires and just hook up the cannon and motor directly to power without the control box?
and yeah the remote's light comes on and everything
Theres a way to do it by bridging curcuits on the circuit board, but i wouldnt recommend doing this if you dont have the wiring diagram or an understanding of electronics.
There should be a plug that goes to the motor from what I remember, if its a 2 pin plug, you cant go wrong, positive one side, negative the other, reverse polarity will make it spin the other way.
To test the motor you dont need the control box. Just get 2 pieces of wire connect one to the positive of your battery and one to the negative then connect the other ends of the wire to the terminals of the plug coming from the motor. And reverse the wires to go the other way.
I had one fitted to my falcon not too long ago, I just had mine dynod on the weekend.
Valve open: 198.9rwkw
Closed : 138.0rwkw
When open there was no restriction at all compared to my previous straight through muffler. This was with a full 3" system and a very big cam.
They feel very gutless when closed. I would only use it when you really need to be quiet.
ive looked into it a bit more, and i really cant figure out what the problem is, and im a bit hesitant to apply 12v directly to the motor without any resistors or fuses in between, just not willing to risk blowing the motor (if its not already blown)
i called up a shop near by and they said they'll have a look at it and diagnose the problem for free. guess thats worth a go.
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
