Complete 3 inch turbo back exhaust for a 33 gtst.
Bellmouth advance dump modified to fit a hotdog muffler in before the cat.
Dump pipe has been painted in high temp exhaust paint (supposedly has ceramic in it) and wrapped.
Cat is complete, not bashed out or "high flowed"
Single straight through box muffler before the rear subframe.
3 inch twin pipes or cannon out the back, both will be provided.
$300 neg.
3.5 inch cat back to suit 33
single hotdog muffler before rear subframe.
Cannon at the rear.
$150 firm.
Brand new fibre glass gtr style front bar to suit 33 gts/gtst
Sold the car before it was fitted.
No holes have been drilled yet.
$150 firm.
Located Canberra, ACT.
Pm, or Text me on Zero 415 055 80 Nine
Cheers,
Jono.
Edited by reaper1721
pics of bumper and turbo back exhaust as requested
The cat is not pictured, but IS included
This is how the exhaust looked when fitted:
Sold the car one week after buying the bar. As far as I could see, it was exactly the same as the bar I had on at the time...just didnt have zip tied up splits and cracks.
Here is a pic:
3 inch turbo back exhaust is SOLD
pics of 3.5 inch cat back below. the exhaust has two small holes as pictured.
comes with two cannons, take one, take both, don't care, same price. One apexi n1, the other is some jap thingo that i can't read because its scratched (look at pics below). second cannon will need some pipe work to fit, has a silencer though.
Also for sale, stock r33 gtst s2 turbo, blown exhaust turbine. has no actuator. $20. hiflow it without taking your car off the road?
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
