Hi,
I'm after some guidance as to RB20DET oil pump clearance and checking before I put it back on. The engine is being balanced with forged pistons and I will be doing some revs with Motorkhana and Drift.
I can't find anywhere on an overhaul procedure or any kind of checks I can to before putting it back on.
Also someone was saying the drift guys have an oil drain coming from the head as prolonged revs end up with all the oil in the head.
Can someone enlighten me or send me a link to some good / factory information please?
Hi,
These aren't from a book (I haven't written it yet anyway) but a healthy pump is usually 0.006-0.008" between the teeth while the pump is out in your hand and while you hold the opposite side meshed together. It's about 0.004" when the pump is installed.
Check the flats with verniers to make sure they are parallel all the way across and then measure the crank across the flats to make sure you are within about 0.010-0.015" clearance there. Check for scoring on the round section and make sure the diameter on the running face is identical all the way around, right up to the edge of the flats.
Clearance to the crank on that section is usually something like 0.006-0.008" but it can vary between engines.
Check the outer diameter of the outer gear and ensure its exactly the same diameter all the way around.
Next, install the centre gear in the pump and make sure it turns freely. Take it out and install the outer gear and check the same.
Now install both and turn it. Make sure it turns very freely.
Now tighten the backing plate down with the screws and make sure you use an impact driver.
Now check the pump still turns freely. You should be able to turn it easily with 2 fingers.
Now pull it all apart and pre-lube it around the rotor area with engine assembly lube or similar. Re-attach the backing plate using new screws and a single drop of loctite on the thread. Once again, impact drive them down.
Remove the pressure relief valve nut from the pump and take out the spring. Turn the pump upside down and the relief valve/piston should slide out cleanly without assistance. Gently place it back in the same way it came out and ensure it slides all the way back down without restriction. Re-install the spring and nut.
That's about it
Edit: and these instructions assume you have thoroughly cleaned the pump already
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 馃槀
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
