Just thought it would be good to start a thread on weightlifting, otherwise known as olympic lifting.
I know down at PTC they do a little bit of it, how much i am not too sure. Markos would be the best on that one.
I've always had a bit of a soft spot for it, and lately it's the only thing that interests me, so i'm just focusing on it atm.
I've trained at a couple of weightlifting gyms and the weights these guys are not only cleaning, but putting overhead is awesome.
Plus they can squat BIG weights, and could probably deadlift a fair bit if they did deadlifts.
So, who does a bit of it, do you focus on it or is it something on the side?
What weights are we cleaning, jerking, and snatching?
What assistance exercises are you doing for the lifts?
Or even if anyone wants advice on weightlifting?
I don't expect anyone to just do cleans and snatches, but i believe if your not doing them you are really missing out on some real explosive strength which would transfer to all your other lifts.
https://www.sau.com.au/forums/topic/415081-weighlifting/
Armando is our best weightlifter
He just won Bronze at the World Masters in the Ukraine
He snatched 114kg and jerked 142kg
He had a crack with 149kg for the Gold, he cleaned it but lost it forward on the jerk
He is 50 years old and lifts in the 94kg class, he also squats 200kg
His best lifts when he was younger were 165kg snatch and 185kg jerk, 250kg squat
https://www.sau.com.au/forums/topic/415081-weighlifting/#findComment-6657536
love Olympic lifting... My old man took me to the World Champs in Melbourne years ago... saw Suleymanoglu lift... I was about 12 but remember it pretty clearly
I actually like watching weightlifting more than powerlifting... watched most of the Londons olympics lifting
unfortunately my mobility is garbage... I can't even overhead squat properly so full snatch is out... never tried a power snatch as I don't think they'd appreciate me dropping the barbell at my gym... I power clean a fair bit... obviously don't go much heavier than about 90kg as I don't want to drop the bar... usually I do sets of 5 hang cleans at about 70-80kg
I also can't front rack the bar properly as my wrists aren't flexible enough... although I'm working on this with some light front squatting
I'd love to much around with oly lifts with some chalk, bumper plates and a decent bar... average gym bars don't spin properly
maybe I could come down for a session with Armando Markos? would be happy to pay for his services etc
https://www.sau.com.au/forums/topic/415081-weighlifting/#findComment-6658356
Simon, Armando was a great snatcher, he was known for it
Nick, I was at the same comp in Melbourne
Nick, we actually use Max for weightlifting lessons, you'll know why afterwards
The comment on bar spinning. When we got our Zhang Kong, everyones powerclean numbers went up, it makes a big difference having needle bearings over bush bearings in the sleeve
https://www.sau.com.au/forums/topic/415081-weighlifting/#findComment-6658631
Do I remember correctly that Suleymanoglu broke a couple of WR at that comp?
Awesome, can't wait to have a go with that bar... assuming Max's weightlifting sessions are a bit brutal? sounds like something I'd enjoy
https://www.sau.com.au/forums/topic/415081-weighlifting/#findComment-6658762
My bar is shit, already bent and it's 3 weeks old.
Anyway, managed to jerk 125 from behind the neck the other day, got 115 from the front. Now if i could only clean it first :)
Also 5x5 of snatches at 60kg with 30sec rest between, bloody hard as. Went to squat afterwards and thought f this once i hit 160, didn't even get one rep, ha ha, legs were useless
One of the guys at my gym did 30x60kg snatches in 1min52sec, which is crazy, so i want to try and beat that
https://www.sau.com.au/forums/topic/415081-weighlifting/#findComment-6663614
We had a Pendlay, just got rid of it
ABC make a brilliant OL bar, Ryan had one (Airwave)
I have the ladies (15kg) version with needle bearings, awesome bar
I get very good prices from Wayne at ABC, let me know if you want to go down there
https://www.sau.com.au/forums/topic/415081-weighlifting/#findComment-6663901
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
