Staying 2.6 with this car Paul or will you stroke it?
Needs to be a 2.6 for this one for the rally regulations. I believe if I put a 2.8 in it I would need to enter it as a z-tune, due to the year it was made it would bump me up into modern so up against R35's, Lambo's etc. Maybe in a few years the z-tune will get bumped back to early modern and would go 2.8 then.
I Like the colour 8)
:yes: Me too. Not quite KY0 but as close as I think you get in the standard 34 colours.
These tend to go well with the silver.... z-tune front bar, and mu secret s-tune copy bonnet
New bumper reo, EFI loom and a couple of other bits I didn't end up needing because the z-tune bar is one piece where the factory is two. I do have a factory bar that came with the roller in case the targa regs force me to go back to standard gear so will come in handy then.
Engine and gearbox ready to be taken off the subframe and dropped off at Race Pace.
Was originally going to suck it and see if the engine was ok, but thought better and ended up getting it all pulled apart. Was the right choice because there was an 8 thou bend in the middle of the crank, a spark plug tip had come off and damaged the bore a little, and the turbo bearing cages were not in the best shape.
New R34 crank, machining, 87mm pistons up from 86.5mm, new bearings and consumables, reco of the turbos and a good check over everything else.
And the finished product including wing. Once the front diffuser goes on it really completes the look but looking pretty tough at this stage.
At this point a lot of my time starts getting wasted staring at it from different angles.
Cheers yeah there have been many late / all nighters, rolling around on creepers, misplaced tools, gritty eyes and grubby hands - and of course lots of swearing!
It's all worth it now its all up and running, engine running sweet, suspension set up right and blasting around the tracks having fun.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
