Staying 2.6 with this car Paul or will you stroke it?
Needs to be a 2.6 for this one for the rally regulations. I believe if I put a 2.8 in it I would need to enter it as a z-tune, due to the year it was made it would bump me up into modern so up against R35's, Lambo's etc. Maybe in a few years the z-tune will get bumped back to early modern and would go 2.8 then.
I Like the colour 8)
:yes: Me too. Not quite KY0 but as close as I think you get in the standard 34 colours.
These tend to go well with the silver.... z-tune front bar, and mu secret s-tune copy bonnet
New bumper reo, EFI loom and a couple of other bits I didn't end up needing because the z-tune bar is one piece where the factory is two. I do have a factory bar that came with the roller in case the targa regs force me to go back to standard gear so will come in handy then.
Engine and gearbox ready to be taken off the subframe and dropped off at Race Pace.
Was originally going to suck it and see if the engine was ok, but thought better and ended up getting it all pulled apart. Was the right choice because there was an 8 thou bend in the middle of the crank, a spark plug tip had come off and damaged the bore a little, and the turbo bearing cages were not in the best shape.
New R34 crank, machining, 87mm pistons up from 86.5mm, new bearings and consumables, reco of the turbos and a good check over everything else.
And the finished product including wing. Once the front diffuser goes on it really completes the look but looking pretty tough at this stage.
At this point a lot of my time starts getting wasted staring at it from different angles.
Cheers yeah there have been many late / all nighters, rolling around on creepers, misplaced tools, gritty eyes and grubby hands - and of course lots of swearing!
It's all worth it now its all up and running, engine running sweet, suspension set up right and blasting around the tracks having fun.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
