Do you have: gear boot surround (with the plastic piece that locks it onto the stereo surround) , left hand dash vent , hand brake boot ,front upper control arms , clutch master and slave (and everthing between) and a clutch pedal?
  • Replies 120
Posted Images
R32 mirrors $70 each
2xaircon climate control $80 each
N1 GTR headlights $300 a pair
2xbonnet $90each
L-R front guards $150 each
front calipers and rotors $200
Front LCAs $120 a pair
front r32 reo $120
r32 brake master with booster $120
r32 clutch master cylinder $30
brake and clutch pedal $150
manuel rb20 tail shaft $100
dash $400- comes with all vents non cracked.
door cards $50 each
washer bottle $60
rear window $500
drive side window switch $100
window reg switch sensor box $50
window reg $100 each
door shell $100 each
boot no wing $100
stock diff $150
steering colum surround $50
fuel tank $150
hand brake cable and hand brake $90
tail lights $60 each
rear reo $100
rear bar $80
dash cluster $80
cluster surrond $80
carpet $100
rear parcel shelf $60
GTR front strut bar $100
CD/gear shifter surround mint condition $100
CD/gear shifter surround painted white eith top crack but not all the way through $50
gear boot $15
hand brake boot $10
driver side dash vent $60
nissan din pocket $20 (the little shelf under cd player)
side skirts $140
rear pods $100
Tein HE drift coilovers $900
sun visors $10 each
rear veiw mirror $20
glove box $30
rear ashtray from centre console $20
under steering wheel panel $30
BBS 17inch 8+35 and 9+35 $1200-
Plenty of interior and stock suspension for sale just ask I may have missed it in my list..
Which seat belts you want?
No compliance mine is a sticker on the tower which voids the moment you pull it off
full set. is the sticker purple?
the reason i ask this is i do not want the klippan items i want the OEM ones.
Ill need to check my parcel shelf and send you a pic =]
umm ill need to go out and check it tomorrow seat belts are seat belts to me lol
no probs.
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
