  • Replies 120
Posted Images
Washer bottles $60 each..
BBS 17inch 8+35 and 9+35 $1100- (genuine)
under dash trim panel $15-
white surround $50
Rear parcel shelf $60-
A Pillar trims $30 each
speedo cable $90-
glove box no key $30-
center console dash panel radio surround $50-
mint black center surround $100-
Rear quarter trims $30 each
rear seat belts $80- front seat belts $70-
nissan din pocket (shelf for under cd player) $20-
rear trim $50
headlights $250- reo $100 bonnet $80-
driver side dash vent $50
climate control panel $80-
hand brake cable and hand brake $90-
4.3 R200 stock LSD $150
Edited by 05lde
R32 mirrors $70 each
2xaircon climate control $80 each
headlights $250 a pair
bonnet $80each
front calipers and rotors $200
Front LCAs $120 a pair
front r32 reo $100
r32 brake master with booster $120
r32 clutch master cylinder $30
brake and clutch pedal $150
manuel rb20 tail shaft $100
dash $400- comes with all vents non cracked.
door cards $50 each
washer bottle $60
rear window $500
drive side window switch $100
window reg switch sensor box $50
window reg $100 each
door shell $100 each
boot no wing $100
stock diff $150
steering colum surround $50
fuel tank $150
tail lights $60 each
rear reo $100
rear bar $80
dash cluster $80
cluster surrond $80
carpet $100
rear parcel shelf $60
GTR front strut bar $100
CD/gear shifter surround mint condition $100
CD/gear shifter surround painted white with top crack but not all the way through $50
gear boot $15
hand brake boot $10
nissan din pocket $20 (the little shelf under cd player)
side skirts $140
rear pods $100
Tein HE drift coilovers $900
sun visors $10 each
rear veiw mirror $20
glove box $30
rear ashtray from centre console $20
under steering wheel panel $30
BBS 17inch 8+35 and 9+35 $1200-
rb20 speedo cable $90-
washer bottles $60 each
rear parcel shelf $60-
A pillar trims $30 each
glove box $30-
rear quarter trims $30 each
rear trim $50-
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
