hey guys I have some parts here that I was planning to use on my car but have decided to leave it as it for now...
I have a r32 rb20det ecu with a nistune board installed it is tuned for 850cc injectors, z32 afm and a bigger turbo etc - $400 firm
a mint set of r32 gtr rb26dett injectors all cleaned and flow tested - $250
z32 afm with plug/pigtail - $200
a set of super spark coilpacks only 6 months old I'm not really keen to sell these but will take $300 if someones keen...
I also have a lot of r32 and rb20det parts so if you need something hit me up.
Im located in algester 4115 but am happy to post stuff at the buyer cost :)
please contact 0420 767 957
cheers
still got that rb20det?
That was for a Nistune ecu not a engine mate...
All the item's listed above are now sold but I am wrecking a complete r32 so check my other topics :)
Cheers
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
