Hi mate
i was wondering if anyone can point me in the right direction. I have never gotten a straight answer regarding the PFC. i really don't except one either. I was wondering were in the power FC i can set or tune out a bigger turbo surge after revving the engine in neutral, or at stand still.
I have done some upgrades on my R33 GTR, and it runs great. First i upgraded to a 6boost top mount and a GTX3582r turbo with all other supporting mods to make it work. I then tuned it own my own. I'm still learning, but find it to be way more sensitive on a GTR than a GTS-T. Hence the 2 AFM
Well this is whats happening. after revving the engine it wants to stall but don't after it comes to idle. I can see it push out black smoke at close to idle. I feel as if it has to do with the bigger turbo still spinning to fast and pulling air through the AFM's. i have the BOV's vented back in through a Greddy Y-pipe so I'm thinking that the location of the returning air is fine because the Y-pipe has a spot for the returning air. I notice that i can drive through this phenomenon if i keep in mind that i have to let the turbo slow down by clutching in at the last moment. Only then does it not stall, or come close to it.
any help would be appreciated
Thanks Mate.
https://www.sau.com.au/forums/topic/415133-power-fc-help-afm-surge/
Obviously you are using custom intake piping for that turbo, photos will help. You need to look at things like AFM reversion where the angle of the air should be pointing away from the AFMs (and towards the turbo) when returning via the plumbback, whether there are any bends after the AFMs etc.
I will take some photos in the morning mate,because i don't photos of the y-pipe on the car. i also have none of the BOV's venting back. so what you are saying is there is no way to tune this phenomenon out using the PFC???
From what i can remember the pipe has like a sleight angle pointing back into the turbo about 5 degree's very small. And I'm running twin HKS SSQ BOV's
vented back in.
So its all mechanical???
fit a pair of 35 gtr afm they fix stall issues when running old style afm
although stalling issues don't exist if you ask nismoid
ps I have a pair for sale $250 each will do upto 600rwkw in twin application
basically setup for z32 replacement
http://www.phoenixs.co.jp/bigsite/rb26dett/rb26dett_4.htm
Edited by 1400r
i thought that the AFM are to close to the turbos, but there just isn't any more room under the hood for the set up. how can i get them to be further from the turbo is there isn't anymore room.
has any done the setup that 1400r is talking about? is it true that the R35 AFM could be a replacement for the twin Z32. i wouldn't mine buying them if they can help with my stalling issues, how is it different 1400r, and what about the recalibration for the R35 AFM or are you saying that the Z32 AFM calibrations in the PFC work?? i will look into this and source information regarding this setup i find it interesting.
i will take photos of the set up close up and post the return to the turbos.
thanks again you all have given me a lot to think about.
check the link I posted up plenty of highend tuning shops doing it in Japan
tuner would need fc logic pc software min and you'd need to check with them first
that they can edit the vq map in the fc logic software Im sure nisstune guys would be willing to assist the tuner with this
as from knowledge you'd be the first trying with power fc
3 cars done in SA with nisstune already r34 neo s14 sr and some sort of rb R31 that fitted 35 sensor to fix idle issue
when car was fitted and tuned with a hpx sensor
there a one way sensor so when air pass back the wrong way over the sensor it isn't picked up
Edited by 1400r
Can anyone show me there set up for twin z32 AFM and there recirculation pipe.
I'm looking for a idea of how far away the AFM have to be from the turbo and the location or distance of the relocation pipe from AFM and turbo.
the idea is to stop stalling problems
thanks
i was hoping you would take this up R31Nismoid and thanks, the only way to do it i think would to place then in the inner part of the fender well.
This will mean more fab work. Why would the stock BOV's help the phenomenon out? i thought that they all work the same, can you go min to some details how this would make a difference thanks for mentioning this as well Adriano. i just don't understand why it would make such a big help?
i also would like to pass this by you all. i have a D-jetro PFC in my room just sitting there, can it handle the same power out puts as AFM?? are they easy to tune like the L-jetro's.
should i drop the L for the D setup and what advantages would i gain over the L set up???????
would i be able to run ATMO BOV's.
thanks a million
D-jetro are no where near as good as afm based pfc's. I've tuned plenty of d-jetro's and they never tune as nice.
You need bov's that will vent under vacuum (less than 20 kpa of vacuum) - this is how the factory valves work. This will minimize reversion.
You could also try the afm's that 1400r is selling. I personnally haven't tried them but I have used similar item in other ecu's with no reversion issues.
I am willing to give the r35 a try, but only after the home work on them is done, i need to see that people are having success with them on the aspects of calibration in different pipe sizes. I have some sort of knowledge on the items but not like some gurus in here. the power FC has the air flow curve for a couple of Nissan AFMs, but none for the R35 AFM's
you mentioned that you used other items, can you mention a few that works for you, i feel like i should pull my Haltech PS2000 out my GTST and put the dam thing in my GTR lol.
thanks for the input mate.
you wont need to worry abut different pipe size unless you make over 600rwkw as each 35 afm in z32 pipe size will do 300rwkw
the fc has no preset 35 amf map yes hence why you'd need fc logic to edit say the q45 afm vq map to suit
http://minkara.carvi...9/blog/c787696/
dude running r35 afm on a wrx with power fc
I've emailed the fc logic guys for you easiest way to find out
Edited by 1400r
The r35 afm's look almost identical to the Subaru wrx afm post 2002. Mazda also use similar denso sensors. They have a sampling port that meters air perpendicular to the flow of the incoming air. This means that they are almost impervious to reversion.
I've tuned a lot of Subaru and Mazda oem ecm's of all sorts without any revision issues.
i'm no guru, mate. i would like some one to provide the air flow curve or moded values for the vq curve, and i will buy 2 of them asap.
if you can provide these curves then i think that all your R35 AFM's will go like crazy. The jap links are in Japanese and that helps no one mate.
I do believe that the what you describe will come to be more and more main stream, and that you are on to something good, but i have to time the way i jump on this idea.
thanks again why are you selling yours
They are better AFM's for reversion but they can still play up, depending on how the BOV is plumbed back. VQ/WRX/R35 sensors are all very similar, but the hassle with the inbuilt processor playing up doesn't seem worth the hassle, especially with no diagnostic/limp ecu protection.
I went MAP and never looked back.
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
