I'm getting a set of 34 gtt rims stock ones and its going on a r33 gtst with 440 at the rears the main goal is to have the ultimate sleeper look like bone stock from the outside
Would anyone know what's the widest wheel you could fit on a r34 gtt rim
https://www.sau.com.au/forums/topic/415153-r34-gtt-max-tyre-size/
:blink:
Get 34gtr wheels then and get some width at least....
Well its a 7.5" rim so 255 def not advisable / legal. Pretty sure 225 is the widest you can legally fit on a 7.5".
For a "stock" nissan wheel, your options is basically limited to R33 GTR at 17 X 9 +30.. Can fit up to 255s. 370Z wheel offsets are too weak at the front and aggressive at the rear but I guess you could make them fit if you were really really keen..
    • Yes, I know馃檮 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole馃ぃ
    • You鈥檒l be very upset when you bust that too not to mention the gearing totally sucks. Don鈥檛 do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30掳 silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30掳 silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
