Hey guy's I know this has been done to death but every post i have read hasn't fixed my problem. The air con in my 32 hasn't worked since i bought it . Ive sent it to a mechanics and $300 later its been re gassed (which wasn't needed) and they proceed to tell me its not fixed.
Got home checked the fuse under the dash its blown, replaced it air con works perfect for about 20 min and the fuse blows again. I've replaced the fuse many times since and now it blows within a few seconds of turning on the A/C. I've run the diagnostics on the climate control and have established my blend door servo motor is rooted. What i want to know is if this would be causing my fuse to blow? Compressor seems fine, clutch kicks in, all relays seem fine I'm stumped at what else it could be and don't particularly want to go to an auto elec if i can avoid it.
Also worth noting my condenser fan also does not work, has power to the fan and when the fan is hooked directly to a 12v source it runs fine, What could this be?. Any help would be greatly appreciated
cheers Jerry
https://www.sau.com.au/forums/topic/415161-r32-aircon-blowing-fuses/
It would be helpful if you let us know what you found, so we don't just repeat what you're already read.
For me this happened when the mag clutch solenoid pulled too much current. Measure the resistance of it with a mutlimeter. Off the top of my head its supposed to be 3.8ohms, but if you measure it and post back ill look it up.
There's a thread on here somewhere that shows you how to wire up the condensor fan so it blows whenever the air con is on (which is a worthwhile mod even if the fan is working normally)
Fan isn't for aircon. It's for engine when too hot
I would be leaning towards compressor. Plenty draw too much power after they have warmed up. When its popping straight after turning on, disconnect compressor and see if it stops
Cheers, checked the resistance of the clutch and its only approx 1.6ohms according to my temperamental multimeter. I'll unplug the compressor and see if it stops blowing fuses this arvo.
Ok the resistance is supposed to be 3.5 ohms. With 1.6 you'll be pulling a lot more current so that correlates with blowing fuses. Pretty sure you'll need a new solenoid for the mag clutch.
it is definitely ur ac clutch electromagnet which engages the pump that is drawing too high of a resistance. ohms's law states that I= v/r, so if u plugged in ur numbers u r exceeding the current rating of the fuse. i had the same exact situation, and i found a right up up on here to change the coil behind the ac clutch not a fun job but yea it can be done in the vehicle.
have fun and good luck
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
