I forgot about the ducting photos.
These two arent from an australian supercar they are from a current Newzealand V8 touring car.
They run a controlled Wilwood calliper and controlled brake duct.
Our local supercars use an almost identical ducting setup thats kevlar.
Hi sorry if I might be hijacking your thread, but this seems to be the best place to ask.
I drive a 99 R34 25GT, at the moment it's a daily driver but it's also a long term project car (Engine won't really be touched until I get myself another car for a daily driver).
I've taken it on one track day so far and I'm looking at taking it on the track a couple of times a year if that, nothing too crazy.
But I'm looking at upgrading my brakes with a big brake kit. I was looking at the D2 kits but I'm not sure what I should be getting. Can someone please give me a couple of options on what to get? I'm not sure on rotor sizes either. I'm hopefully getting TE37s soon also so they would have to fit under those..
Thanks for any help in advance
So is the air and water vapour mixture just directed onto the face of the rotor on that side?
The 330mm D2 kit is the safe bet, they will fit under most 17s. If you want the 355 you will need 18s, the TE37 design is great for caliper clearance and should not be an issue. Really, the question should be what size tyres do you want to run (17s are much cheaper than 18s) then choose the wheel, then choose the larger or smaller brakes to suit. Either kit will be fine unless you use the brakes more than you need to ;)
Brad, we need pics of the other side of the rotor...I'm willing to bet the vent runs to the centre of the disc not the outside face, but that's not how it looks in those pics
here is a couple from both sides of a VY taxi.
This car has a front mounted rack unlike the previous car that was rear mounted.
The ducts on this one are mounted at the front of the upright obviously.
The NZ VY has a very similar thing but smaller.
There is a carbon peice that locates onto the duct which adapts into a 3inch spiral tube to allow the flex before entering very similar kevlar ducting to the front bar.
The kevlar parts from that VY are removed at the moment and being repaired.
lots of space when there is no driveshaft going to the hub eh? Interesting the shape of that final duct, I bet they have done a lot of testing about how much air to aim directly at which part of the disc vs how much to direct at the centre
Real race cars only have two drive shafts Duncan ;)
I wouldn't want to change the ducts that's for sure. That car has done 3 Bathurst 1000 events and finished all 3 times as well as sandown enduros so if say they did something right.
The differences between teams is interesting to look at though.
A lot of the time they run the cars with the ducting blocked off at the bumper.
Spot on the money. There is a properly made up funnel that crates a neat shape that suit the inside of the rotor.
Jacking up a supercar now to take photo of it.
I see said the blind man! Great job Brad, thanks mate.
No kidding with space due to no driveshafts!!!
Anyone wants Alcon rear kit ? SInce they offer free shipping for rear kit, I will order it, and will keep it for spares, but I thought if anyone wants rear too we can drop price little bit http://www.jdl-brakes.com/alcon-adv-extreme-brake-kit-rear-4-pot-o350x28-nissan-skyline-r32-r33-r34-gtr.html
Anyone wants Alcon rear kit ? SInce they offer free shipping for rear kit, I will order it, and will keep it for spares, but I thought if anyone wants rear too we can drop price little bit http://www.jdl-brake...33-r34-gtr.html
I got mine Alcons from JDL, great service and stuff
These seem to be pretty cheap http://www.ebay.com....=item2ec12dc8e3
Does anyone have experience with them?
I bought my first R32 GTR with Wilwood 330 mm kit on it. It was good, but not better than Brembo from R34 which I fitted few months later. Maybe I had some issue with pads from this kit, and that's why it didn't perform as it should. Anyway, I wasn't happy. It's still my #1 http://www.jdl-brakes.com/special-offer-alcon-adv-extreme-brake-kit-front-and-rear-nissan-skyline-r32-r33-r34-gtr.html
Those wilwoods are a very average setup overall.
The callipers have a terrible open bridge design and they flex horribly. The lug mounts they use also flex a lot if you dont have the callipers spot on centred to the rotor.
I've used them on lighter road cars like MX5's and pulsars in the past with little problems
I fitted a set up to a Toyota 86 a fortnight ago only to remove them after a track day and change over to an AP calliper. The pedal feel was horrendous at 3 corners at Wakefield park.
AP's being tested on Wednesday but already on the road they feel so much nicer under firm braking.
  • 3 weeks later...
I have Alcon front kit with 343 mm rotors, but thinking about these kits http://www.jdl-brakes.com/special-offer-alcon-adv-extreme-brake-kit-front-and-rear-nissan-skyline-r32-r33-r34-gtr.html What wheel do I need to clear 6 pistons calipers with 365 mm rotors ? 18x9 +15 would be ok ?
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
