So.. trying to find someone reliable/affordable to machine dogbones etc. for my V8 Supercar alcons is proving to be a bit challenging. (My calipers https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-ash4/1094662_10153125748100301_2119536866_o.jpg )
The Alcon extremes (http://www.jdl-brakes.com/alcon-adv-extreme-brake-kit-front-6-pot-o365x32-nissan-skyline-r32-r33-r34-gtr.html) appear to be a much easier upgrade as they come with all the parts ready to install.
Aside from running a smaller rotor, what are the main differences between this kit and the calipers I already own?
Brakes are for a 32 GTR track car, mainly doing sprints.
Well the kit you have allows you to run a bigger rotor with better wheel clearance. It is lighter than the Advantage caliper. But those things are all bee's d1ck things. The one main reason why your calipers are superior is the titanium pistons work waaay better at keeping the heat from the pad out of the brake fluid.
But again, the Advantage kit is pretty damn competent on most track GTRs. Especially if you are going to get stung for $600 for a pair of radial mounts. $800-1000 for the hats and bobbins to work with the V8 Supercar rotor...then lines and pads. Buying $1500 calipers can quickly add up to serious money if you dont have a line on good combination rotors and hats.
If you are going to run those calipers I personally would go brab some off the shelf 380x35mm rotors, either aftermarket or off an R35 and then just pay the money for the radial mounts
Lug mount, is your traditional mounting style that comes standard. Radial mount calipers differ, in that the caliper bolts go through the top of the caliper to the upright. It's regarded as the better, stiffer way to mount the calipers. You can get radial mount dogbones.
So if I run R35 rotors I don't need custom top hats & bobbins?
Is a radial mount the same thing as a dogbone? Who does them for $600?
You can run whatever hat/rotor combination you like but Troys point is that the replacement cost of the rotor (or hat and rotor) is one of the big considerations in its selection. By using a part from a certain vehicle (eg R35) you are getting a component that will be made by a number of different manufacturers which will help keep the price down. Eg Project Mu 324x30 hatted rotor is thereabout of a grand. The 345x32 is double that. The other cost consideration is the price of a pad. same story there. Buy an orphan pattern and you will get screwed every time you need pads.
Yes a dogbone and a radial mount are, essentially the same thing. A radial mount uses bolts that align radially to bolt up the calliper, a dogbone has locating bolts at 90 degrees to that - hence the same as it looks a bit like a dogbone. You need to find a machine shop and give them some drawings. I have tried and utterly failed to find someone for this sort of thing. But this is a one off cost, not a recurring one.
I use Alcon front and rear kit for one year on my R34 GTR. So far 12 track events, and these brakes are best mods I've ever done.
Some 17s ... not all 17s. Based on my experience with 343mm setup and CSC calipers, AP CP5555 and F40/50 calipers and 343mm rotors thinhs like AVS Model 6, Work XD9s, 57 Gram Lights, CE28s etc wont fit inside 17" wheels. Teh CE28s fitted but not enough clearance
Things like Weds, LM GT4s, TE37s etc will do it easy. I have not tried them but people seem to enjoy some luck with Enkei RP-F1s etc
If you want to guarantee fitment inside a 17" wheel then you need to go 332mm rotor
Have just ordered RS 19's for the front for the advantage calipers on a R33 GTR. Will report back.... Anything would be better than the 2500's.
Did you mean DS2500 or DS Performance ? I thought they come with DS Performance http://www.jdl-brakes.com/special-offer-alcon-adv-extreme-brake-kit-front-and-rear-nissan-skyline-r32-r33-r34-gtr.html
DS Performance pads are better than I thought. When mine kit came, I was ready to put RS29 for first use, but my mechanic put original pads ( DS-P ) by mistake. I can say, for normal street use, they are not bad. I haven't tested them on track, but if someone use car on street only, DS Performance are not bad choice.
I heard that Alcon kits what we buy, are street legal in Europe, that's why they come with street legal pads.
You could be right.
Either way, the pads that the kit comes with are junk.
    • 1994 Series 3 R32 GTR. Freshly built as the perfect weekender. Has many brand new Nissan OEM pieces (some you can no longer source). Last serviced (April 2024) at V Spec Performance, Melbourne, Australia. Feel free to DM me if any questions. Asking price: $190,000 AUD.  Engine RB26DETT Original 05U block Factory R32 crankshaft CP 86.5mm forged pistons Spool forged rods Factory cylinder head – rebuilt Factory valve train Factory camshafts Factory inlet manifold Factory throttle body Garrett dash -5 turbos Custom intercooler piping with Plazmaman clamps Plazamaman 100mm race intercooler Turbosmart BOV Tomei fuel rail 660cc injectors Goodridge 9000 series fuel lines with crimped fittings Stainless steel front pipes Tomei titanium exhaust with stainless steel cat converter Spit fire coils Powder coated rocket covers New Nissan coil pack emblem badge Fully repainted engine bay in Factory Black Refurbished ABS unit New Nissan brake master cylinder New Nissan brake lines New Nissan clutch master cylinder New Nissan washer bottles Custom catch can (powder coated with Goodridge lines) Steering rack rebuilt New Nissan power steering lines New Nissan AC lines A/C compressor refurbished AC condenser refurbished HPI radiator and new thermos fanes New radiator fans NOTE: All nuts, bolts, fixings new or zinc coated Driveline Factory 5 speed gear box rebuilt Xtreme twin plate clutch Stainless steel clutch line Rebuilt factory transfer case Custom one-piece tail shaft Rebuilt factory front diff Rebuilt factory rear diff Suspension HICAS deleted Bilstein dampers IKEYA formular front and rear arms and tie rod ends New bushes wherever possible Whiteline anti roll bars (underneath car only) Brakes Brembo F50 front callipers – 4 piston AP racing 380*32 front rotors, J Hook design Custom floating hat and calliper mounts Brembo 4 piston rear callipers PFC pads Stainless steel braided brake lines Body New Factory Black paint job Ceramic coated exterior panels New Nissan aluminium bonnet (super rare) New Nissan headlights (super rare) New Nissan indicators New Nissan front bar New Nissan front lower lip New Nissan head light and bonnet seals New Nissan windscreen cowling New Nissan wiper arms and wiper blades New aftermarket windscreen New Nissan windscreen seal New Nissan front doors window surrounds and seals New Nissan rear quarter windows (must replace for proper paint job) New Nissan rear window surrounds and seals New Nissan side skirts New Nissan boot badges New Nismo rear bonnet lip New Nissan guard liners Interior New Nissan lens cover over cluster New Nissan gear boot shift New Nissan gear knob New Nismo steering wheel New Nismo floor mats New Billet Handbrake lever New Nissan OEM pocket facia to replace radio Underbody Original stone guard removed and new stone guard coating applied Powder coated front and rear cross members Fuel lines painted to match factory colours Fuel tank removed, cleaned, repainted and refitted All nuts and fixings cleaned, repaired and zinc plated Wheels Rays/Volk racing TE37 18 x 10.5 + 15 in Bronze Yokahama A050 265 x 35 x 18
    • @Supernanoyour car has ended up in my hands and I was wondering if there has been any work done to the motor?
    • Sigh... yeah OEM mount rear battery, very R33, very demure, very mindful.
    • Would need a substantial current draw in the car to make a bunch of sparks. Obvs to now test resistance to ground of the car's B+ lead. If there's a short there, you'll see it. Only likely place for that, as you suspect is alternator. But there is also the possibility that rats have had a chew on some insulation. Shitbox has the battery in the boot, yeah? Plenty of cable to attack.
    • Oh, I thought of that too... I disconnected the battery and hooked up the leads direct to the car without the battery in place. Sparks... I suspect the following: Alternator has decided to kill itself Starter has decided to kill itself I'll recharge the battery, then unplug both, and go from there. The above might take 6 months - however I did buy a Victron 15 AMP trickle charger, apparently it's better than CTEK? Amazon, delivery by tonight. https://www.amazon.com.au/Victron-Battery-Charger-15-Amp-waterproof/dp/B07P4LMMMD?ref_=ast_sto_dp
