Hey Roy yeah i didnt even think to mention what pads they were front and rear lol. It is squirmy when cold under hard braking and improves slightly when hot under hard braking only. ie on the limit of abs kicking in. The squirm is very manageable and doesnt feel like its going to come out on me like Ash mentioned. At one of the drive days I had an instructor with me in the car and he thinks there is too much rear braking causing it.
Odds are the DS2500s work from cold and the PMUs need to be over 300deg C before they are in their operating range.
So the DS2500s are offering a higher co-efficient of friction from cold when the fronts are still thinking about getting up to temp. If you still have the DS2500s that the car came with slap them back in and see of the problem goes away. If it does than thats the issue.
Has anyone ran a Pagid RS4-2 with their Alcons. On paper they are a tad better than DS2500s....they are the next pad I am trying
  • Like 1
Loved them personally - good compromise for a car that still gets street driven.
Once they are around 30-25% left they tend to break up if you hit the track or push them hard on a hills run etc so just be mindful of that, but then they are a lot cheaper than other options that don't.
Decided to bite the bullet and order a set of 356mm D2's from import monster next week as my factory rotors and pads are due for a change.
Does anyone know what the pads that come with them are like on the track? Should I bother getting some decent pads straight up?
The street pad they come with isn't bad for street and what they are in a standard kit form type thing.
But having then changed mine to DS2500, you can certainly notice a difference/improvement in all areas... So if you are just circuit then yeah, change them. If just street duties leave them as is...
Or... get a set of DS3000 or another track only oriented type pad and swap the D2 pad back in afterwards for daily driving (some people do that too)
  • Like 1
Are there any issues running 2 different pads on the same rotor? Like issues with bedding them in etc?
I dont have big brakes yet as i am a sook but just for interests sake?
Recently found out that new Project Mu pads don't like an old rotors (that has another brand pad material on them), makes them hard to bed.
Otherwise have not heard of that before then and it was only that brand. I know people who's swapped DS3000s in for a track day and back to a shitty pad for street and it was ok so could be select situations
As always the answer is it depends. You are odds on going to have all sorts of problems if you are going from a semi metallic pad to a ceramic style pad.
From there you can also have problems when simply changing pad compounds. Best bet is that when you go from your street pad to a race pad make sure you do a weeks worth of kms on the race pad in light duty drives. The cold pad will generally not get up to temp and be rather abrasive. Give the rotors a good wipe down with some brake cleaner and then on the way to the track (or night before) follow your usual bed in procedure.
Like wise when switching back leave the race pad in for some street driving to wip pad deposits off using the high friction-cold pad then swap over to your street pad and bed them.
It worked ok for me when I was running Hawks vs RB74s. But frankly that was back when I ran 280mm std brakes and I think with any half decent brake setup then you can quite easily get a pad that serves both purposes these days
You can...but when you are targetting a runout figure lower than .15mm...many say lower then that in performance applications with large rotors then I think most people frown upon rubbing an abrasive on a rotor face in an uncontrolled manner. Also be careful of the grit you use as you dont want to "polish" or improve any surface face that will encourage glazing
  • 4 weeks later...
I heard that is possibility to get 370 mm rotors for Alcon Advantage Extreme. I run with 365 mm kit front and 350 rear, same as here http://www.jdl-brakes.com/special-offer-alcon-adv-extreme-brake-kit-front-and-rear-nissan-skyline-r32-r33-r34-gtr.html but will need to change rotors soon, and I was thinking about bigger rotors with hats. Can anyone confirm this ?
Stop being weak and go the big boys. My Alcons look the same to the eye as the Advantage Extreme that you are running but they take a bigger rotor in 380 x 35.5. That is about the smallest diameter you should run and they take up to 410mm! But the real benefit is the extra 3-4mm in width and vane size. IF braking is borderline than you have a rather epicly powerful and probably heavy car and 5mm rotor diam will make stuff all difference. Not unless that diam increase also means a change from 48 vane rotorss to 72 vane for instance
I bought R32 GTR, and I plan to buy and install Alcon brakes on this car. Question : does anyone here, plan to order Alcon soon ? I think JDL would be keen to offer little better price for two buyers.
I took two kits off him when I got mine. He didn't give me anything off, however, it's worth a try.
They can give little discount, because I've already bought of them something for my R33, with other forum member, and we received additional £100 off.
Edited by V8cat
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
