Just finished putting my R33 GTR back together after changing the headgasket,
Took a few cranks to get it started but when it fired up it sounded smooth and was idling well, oil pressure looked normal, but shortly after a strange whining noise was coming from the car.
I know my thrust bearing was on its way out (you can probably hear that in the vid) but unsure what the hell has happened now!
The battery seems to be a bit low, we have had it on charge but isn't providing as much kick as it should.
Also a sound of escaping air comes from the car after turning it off.
I have also replaced my timing belt with a new OEM nissan one, unsure of how tight they are ment to be, could it just be too tight?
The noise is also horribly amplified due to my shitty phone camera and being in a shed
http://youtu.be/8-tdbWMadnI
Edited by Booki
Very hard to tell but does sound to be belt or idler bearing related.
I would take off your outer belts one at a time and start it briefly in between removing each to see if noise still there.
Spin each of the idlers/tensioners and auxillaries (alternator, water pump, a/c comp) to see if they make any noise or feel rough to turn.
If it's still making the noise with all belts off it's probably going to be the timing belt or again a pulley bearing.
Just drained to the oil,
Does this oil look water contaminated to you?
I threw in some Gulf Western Synx6000 and thats what it came out like. Total run time of the car, maybe 3 minutes?
Note: I filled my radiator up with just tank water to check for leaks/problems before throwing in coolant.
Just took out the spark plugs now, none seem wet, Top of the pistons look a little "moist" could it just be petrol? Getting paranoid again!!
Definately timing belt too tight. Especially being oem one. Gates racing ones make a bit of a whine when engines hot, but the stocker should be silent. Made this mistake myself also :thumbsup:
Thats bad, real bad, did you have water in oil when gasket blew? maybe residue but thats heavily contaminated
Ouch :(
That was the reason for the gasket change, had cylinder number 5 with coolant and smoking.
Was no smoking when I started it...
I'm hoping its just residual...but after your comment fearing the worst
Threw in the left over gulf western and some other various car oils i had in the shed, some leftover Shell Helix 10w-40 & Valvoline 15w-40.
Ran the car similar amount of time and this came out of it.
Think I'm looking pretty good!!
Note to potential people thinking of running cheap oil - Don't, Oil pressure sucks with these oils.
no idea what caused the blown head gasket.....
if you havnt identified the cause of the blown head gasket (detonation, overheating ...?) then its highly likely that it will blow again
Ill take a guess that removing the stock boost restrictor and running stock turbo's on factory tune may have done it.
Car has never over heated, considering its a R33 GTR 1995 model, original unopened motor I would maybe suspect wear and tear/time has caught up with it.
Otherwise it all looked good underneath
Edited by Booki
sounds like detonation damage to me otherwise i would still be looking for a cause . . .the HG are the fusable link on any motor and under normal operating conditions last a very long time. . .ie ive had unopened motors with 300,000 +ks on the original HG
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
