Yeah maybe take it to a tuner and let them check the air to fuel ratios just to make sure.
My stock computer was running 13 psi and never blew a head gasket. Stock tune with stock or close to stock boost shouldn't cause an issue at all.
Wear and tear could be a factor maybe the the person before you gave the car a thrashing
Could have had a hard life like alot of skylines, but strangely enough my bottom end looked really good, and the fact that the head had never been taken off the car or touched before was also a good sign :)
Was thinking of picking up some shell helix hx7 to rum through the car before filling with motul, should be fine running cheaper stuff for that purpose yeah?
Its $20~ odd at super cheap ;) wonder if anybody actually runs that oil ...
I have done it before just to give it a good clean out. Run some shit oil for 100km or so and just don't thrash it at all. Dump that and top up with quality stuff
Right now I have been running penrite 10/30 or 15/30 for about $50 per 5L and the car likes it.
I just change it about every 3-4 thousand ks
Going in for a tune tomorrow, I've got -7s on it.
Still hearing some hissing, horrible noise is gone so was the timing belt. Oil is staying clean.
Just gotta find this vacuum leak. Any pointers or common leak areas?
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
