id be buying the parts secondhand, aim is mostly some extra bottem end torque, used as a daily, would like a similar setup to say a VL turbo where theres no intercoolers or fancy manifolds..
Does the following sound realistic: assuming 6 or 7psi like a VL turbo would run
secondhand Gt3082/gt3076/gt3540 for $1000
walbro pump $160
possibly fabricate own manifold and short dump 3inch $ 800
some kind of chip/remap of computer $1000 using a fuel reg and stock injectors
bought car as a repairable write off for $1200, just needs some work with the front where the bumper fits, apart from that its very nice and is dual fuel and looked after so would be an nice project for a torquey daily driver..
thoughts anyone?
Edited by SliverS2
plenty of people have done turboed falcons (from ea through to au). 200kw is a very reasonable goal too. i wouldn't be suprised if it was higher though.
the biggest costs will be the ecu, tuning, turbo, piping (exhaust and cooler piping), cooler and setting up oil and water feeds to the turbo. and if you don't have a lsd, you might want to think of sorting that out too. the sort of torque that a 4L NA+T puts out will result in lots of wheelspin from an open diff.
  On 08/12/2012 at 10:52 AM, battery said:
Probably cheaper to sell it and get a ba xr6t...
ive heard alot of reliability issues with ba models and extra weight, and also an au would be unique so with the very small cost so far, a turbo conversion would be interesting, not for drag racing but just smooth torque for daily low revs stuff, be nice to hear a 3076 at work under there... have seen stock ba xr6 injectors, manifolds and dump for very cheap, makes it an attractive prospect, manifold would need some modifying though,
Geetee- thanks mate, id take that turbo, but just at planning/considering stage..
Edited by SliverS2
  On 24/12/2012 at 9:57 AM, NYTSKY said:
fordmods.com
A bit of info there.
thanks, some good info there
most falcons seem to gt3582's upward, i wonder if a gt3076 with a .82 or 1.06 would work well, as id like the turbo to be able to start pulling pretty much straight off the line with the auto like a VL would ,
also from what ive read the stock computer uses a map sensor so it may run safely on low boost, but a chip probably a good idea
Im not a fan of supercharging, i like hear turbo spooling noises and the sudden surge of torque comming onto boost compared to the linear delivery of the supercharger..
Edited by SliverS2
Ive git one in my driveway, remember xr6's have the tickford motor which is higher comp, This one is auto with a built box(the stocker didnt last long) running a 1.06 twin scroll gt35r, i think a 3076 would be fine as long as you ran a 1.06 housing. What are your plans for the dual fuel that would be the biggest issue, but you could put gas injection on it whaich runs its own ecu, just be limited with HP, dont want to end up spending 10K to get the whole thing done
well its a sprint gas system so i dont know how it works, wether it part of the petrol computer of seperate, i know it runs petrol first then after it warms up a bit it switches to gas if selected for gas ,( has a switch for gas/fuel), might need a computer that can handle two maps and have it tuned with two maps?
i really want to make it a low budget setup, $3500 max.. all second hand parts and do fab work myself if i can.. gas injection isnt really an option, i wonder if it could run the turbo on say upto 5psi and then switch for upto 8-10psi, or maybe the gas map would have reduced timing.. certainly throws a spanner in the works
how does the tickford respond the the gt35? is it laggy at all
Edited by SliverS2
you can get kits from snort performance for a reasonable price and they come with pretty well everything.
http://www.snortperformance.com/index.php?option=com_content&view=category&layout=blog&id=9&Itemid=9
No need for expensive manifolds.
Just buy a flange and have it properly welded to the original manifold and make the exhaust to suit. Fab up a bracket to support the turbos weight.
Grab the oil feed from the pressure switch port.
Drain back to the sump obviously. (Sumps not hard to remove of the old XR6's)
Water lines from the heater hoses
Run it with a factory BA cooler and make up some piping to suit.
Not long ago I did a bolt on turbo conversion to a dedicated LPG FG falcon. It made as much power on LPG as any other stock XR6T I've seen. If did require upgraded gas injectors and three LPG pump units with an aftermarket control unit.
Do your research about performace LPG systems, there is massive amounts of performance parts and injectors etc out there.
None of its cheap but the results are interesting
Thanks, ive been browsing ebay and gumtree etc, seems the stock xr6 turbo gear is fairly cheap so shouldnt be too hard to make it a reality,
Im still wondering what turbo should be used, my options as i see it for a budget build are the following
Kando dynamics T67
Second hand garrett
Precision
To make it cheap as possible would need the stock dump to bolt straight up so i think that rules out the kando, and from what ive seen the precision turbos have a 5 bolt housing but looks like its only 0.63, the secondhand gt35's are bit of a gamble though
Any opinions/advice on what turbo selection? im thinking now it has to be a gt3540 spec , a kando with a 5bolt ford rear end would be ideal but dont think that exists?
Edited by AngryRBGTX
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 馃ぃ And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 馃お
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
    • I've never done dial in's just straight up, whatever that's called. I'm far from a drag (racing ) expert.
