Have a chat, post your videos and Pics here!
I've got almost 100 gigs of video to sort through so give me some time folks. I'll try to get a couple of short "teasers" up quickly though.
Huge thanks to the Boys at Unigroup for hosting such a great day for us. As you saw they didn't get a break all day and worked through the heat.
Also thanks to the execs that helped out. Mechanic Sean was on the spot helping people with their shaft and Terry's ice cream fozza van went a treat in the hot afternoon.
https://www.sau.com.au/forums/topic/415240-dyno-day-unigroup-wrap-up-thread/
awesome day guys! didn't get to take many snaps as i wasn't there for long but a few photos trickling onto http://www.facebook....lampoketuckdope make sure to like the page and tag people in the ones that come up! (there will be more popping up throughout the week) :)
as you can see i have a "thing" for Sean's car :P
Very professional jobs done by Yavuz, Mark, Sean & Duncan :yes:
Congrats to all who take care of their cars and didn't have to cause Yavuz 'worry' about possible breakages.
I wanted to try out my Engel fridge to see how long it would take to drain my battery > it nearly did; but not quite...
- but I knew I was in safe hands, so long I wasn't the last one to start up his vehicle to leave Unigroup lol
Fantastic day,nice to catch up with peeps old an new,
but not a lot of ol schoolers left from ten years back.
Still love my 33 do so many ks a year up to 332000 now.
Still feel nothing is better than a jap import. :woot:
Good chatting with everyone including you Chris. I hope you can remember all the names of new acquaintances?
Might see a few of you at the SAU picnic next weekend?
And Kieran, if you're on here, can you make a copy of your insurance company's PDS for me - does your new car have 24U on the block???
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
