Ahhh this thread could get interesting
I want for my GTR:
  • Few nice carbon fibre bits
  • To finish off the fuel system
  • A larger exhaust
  • A hollinger sequential gearbox
  • A big set of balls to help me while I hold on for dear life after all that's done :D
  • Like 1
Really need one of these things, its from in the back of R32 GTR headlights.
So if you have a smashed one please look, ill buy it.
Its an adaptor for the high beam globe.
Dad might have one left over from his smashed lh headlight. I'll point him towards this and let you know
Any one have a staggered set of rims in about 17x8/17x9 with +30 or +35 is offsets for cheap? As light as possible would be awesome lol or even just a pair of rims in either of those sizes would be cool. Need a set of track rims for the mr2 :D
Almost forgot... Need to be 5x114.3 stud pattern please and thankyou
Edited by ryu1605
You should drop an aurion engine into it....and then supercharge it.
That thought has definitely crossed my mind lol. Only problem with the 2gr v6 is that to change to front 3 spark plugs you either have to drop the engine out or cut a hole in the firewall behind the seats in the cabin haha
Just checked with dad, broken headlight is long gone, sorry dude
PM sent.
Looking to Buy;
R33 Rear Pods - White
R33 Side Skirts (Do luck, GTR or standard) -White
Series 2 Drivers and Passenger Seat, Possibly Rears aswell.
A Decent Headunit - Pioneer or other decent brand
Turbo Back Exhaust system - Let me know what you have
Cheers,
Ryan
0404348290
Looking to Buy;
Cheers,
Ryan
0404348290
Hey mate,
I have a rear seat, drivers seat, and a turbo back system if your interested pm me
Looking to Buy;
Cheers,
Ryan
0404348290
I have the 2 fronts and rear 33 s2 seats, pm me if you're interested in them.
Found one in my big bag of electrical stuff, dunno how it got there and its a fluke finding it since its such a big bag of everything.
:blush: thanks for looking for one guys
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
