Ahhh this thread could get interesting
I want for my GTR:
  • Few nice carbon fibre bits
  • To finish off the fuel system
  • A larger exhaust
  • A hollinger sequential gearbox
  • A big set of balls to help me while I hold on for dear life after all that's done :D
  • Like 1
Really need one of these things, its from in the back of R32 GTR headlights.
So if you have a smashed one please look, ill buy it.
Its an adaptor for the high beam globe.
Dad might have one left over from his smashed lh headlight. I'll point him towards this and let you know
Any one have a staggered set of rims in about 17x8/17x9 with +30 or +35 is offsets for cheap? As light as possible would be awesome lol or even just a pair of rims in either of those sizes would be cool. Need a set of track rims for the mr2 :D
Almost forgot... Need to be 5x114.3 stud pattern please and thankyou
Edited by ryu1605
You should drop an aurion engine into it....and then supercharge it.
That thought has definitely crossed my mind lol. Only problem with the 2gr v6 is that to change to front 3 spark plugs you either have to drop the engine out or cut a hole in the firewall behind the seats in the cabin haha
Just checked with dad, broken headlight is long gone, sorry dude
PM sent.
Looking to Buy;
R33 Rear Pods - White
R33 Side Skirts (Do luck, GTR or standard) -White
Series 2 Drivers and Passenger Seat, Possibly Rears aswell.
A Decent Headunit - Pioneer or other decent brand
Turbo Back Exhaust system - Let me know what you have
Cheers,
Ryan
0404348290
Looking to Buy;
Cheers,
Ryan
0404348290
Hey mate,
I have a rear seat, drivers seat, and a turbo back system if your interested pm me
Looking to Buy;
Cheers,
Ryan
0404348290
I have the 2 fronts and rear 33 s2 seats, pm me if you're interested in them.
Found one in my big bag of electrical stuff, dunno how it got there and its a fluke finding it since its such a big bag of everything.
:blush: thanks for looking for one guys
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
