Sorry Kyle. I must have sold my sapre cluster surround for the 32. Had a good look tonight :(
Upside tho, found lots of other R32 GTR interior/exterior parts :D Will post up all my spares after I clean my garage this weekend. Includes:
Awesome drivers side window, new brand name upper control arms, Ahstrays, Kick panels, Boot trim/panels, front mesh :ph34r: , Looks new Drivers/Passengers seat belts, 2 x New Kaixen hids with balasts, BMC, power steering pump, Great full interior carpet, Head unit and other stuff.
I had fun looking :w00t:
Cooma Diesel in Fyshwick is Garrets local rep
If they cant do it or get you what you want no-one can
I'm fairly certain ESP, Trojan, Autotech could order in what you want in the way of Garrets.
They all have the Garret poster - lol
WTB 2860-5 or -9 turbos!
just checking if i can get one local, cause im too lazy to buy interstate LOL
or does anyone know where in canberra i can get turbos balanced?
Check Kudos Motorsports prices on new trubs.
Andrews great to deal with
Have a look on atpturbo.com and Paul at street to track can usually get them delivered to your door for the price listed on there or slightly less depending on conversion rates at the time.
The only issue is the probably don't do them as a set of twins, but it can't hurt to ask Paul...
Edited by Mitcho_7
i agree he is an amazing seller healps you with any of your questions :)
picked up a set for cheaap haha,
anyone know or reccommend a place for the turbos to be balanced and checked?
(for my older turbos)
i also will need tune, i heard autotech is the only place in canberra that can do a nistune?
got board and ecu with a base map for the injectors and turbo, so just need the tune :)
anywhere else can do me a cheap nistune? :)
WTB R34 GTT Series 2 side mirror control panel knob thing...or even that whole panel with the window and door controls.
The little tabs/clips that hold it into the door panel have been snapped off when the power window was fixed, and now it pops out every now and then.
Not really a big problem but it kinda bugs me :angry:
Must be the Series 2 one though... it's a round knob control not the square one.
Bit of a long shot but if anyone can help me out please let me know!
Thanks,
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
