Sorry Kyle. I must have sold my sapre cluster surround for the 32. Had a good look tonight :(
Upside tho, found lots of other R32 GTR interior/exterior parts :D Will post up all my spares after I clean my garage this weekend. Includes:
Awesome drivers side window, new brand name upper control arms, Ahstrays, Kick panels, Boot trim/panels, front mesh :ph34r: , Looks new Drivers/Passengers seat belts, 2 x New Kaixen hids with balasts, BMC, power steering pump, Great full interior carpet, Head unit and other stuff.
I had fun looking :w00t:
Cooma Diesel in Fyshwick is Garrets local rep
If they cant do it or get you what you want no-one can
I'm fairly certain ESP, Trojan, Autotech could order in what you want in the way of Garrets.
They all have the Garret poster - lol
WTB 2860-5 or -9 turbos!
just checking if i can get one local, cause im too lazy to buy interstate LOL
or does anyone know where in canberra i can get turbos balanced?
Check Kudos Motorsports prices on new trubs.
Andrews great to deal with
Have a look on atpturbo.com and Paul at street to track can usually get them delivered to your door for the price listed on there or slightly less depending on conversion rates at the time.
The only issue is the probably don't do them as a set of twins, but it can't hurt to ask Paul...
Edited by Mitcho_7
i agree he is an amazing seller healps you with any of your questions :)
picked up a set for cheaap haha,
anyone know or reccommend a place for the turbos to be balanced and checked?
(for my older turbos)
i also will need tune, i heard autotech is the only place in canberra that can do a nistune?
got board and ecu with a base map for the injectors and turbo, so just need the tune :)
anywhere else can do me a cheap nistune? :)
WTB R34 GTT Series 2 side mirror control panel knob thing...or even that whole panel with the window and door controls.
The little tabs/clips that hold it into the door panel have been snapped off when the power window was fixed, and now it pops out every now and then.
Not really a big problem but it kinda bugs me :angry:
Must be the Series 2 one though... it's a round knob control not the square one.
Bit of a long shot but if anyone can help me out please let me know!
Thanks,
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
