Need an engine crane so i can change the mounts.
Anyone want to sell hire or lend one?
Also does anyone have a good solution for rear harness mounts?
A good harness bar or a way of mounting eye bolts in the right spot.
Yes, seen the plates. They are in cams regs and all the people that sell harnesses have them.
Parcel shelf is strong enough?
Ok. That will be easy then.
Anyone got pics of the install? Pretty please, so i can DIY with confidence it will pass scrutineering.
Mainly the parcel shelf, the floorpan ones will be easy.
Also im getting a sparco seat and a bolt in seat base to be able to remove and install when i want to go to track day.
When it shows up ill see how well the base fits and put up some pics.
Hi, long shot, But does anyone have any Nismo 400R rear and front bars for an R33 Series 2? Recently bought the car, former owner has completely wrecked the front bar and the rear one is pretty disgusting. Really like the look of the nismo kit though.
If not would anyone have any other cheapish kits for sale? KR4 Silver preferred, not essential.
Hey guys,
I'm looking for a place to do a single piece tail shaft (or maybe modify my stock 2 piece shaft) in Canberra.
I've talked to M&A Engineering and they quoted ~$800 for a single piece tail shaft which seems hugely expensive.
Is there anywhere else, or time for a trip to Sydney?
Cheers.
There's a place in Sydney who will make a 1piece shaft using the r33 front / s14 rear shafts I have now for $260.
So far, for a completely new shaft with rebuildable uni's etc it's around $700, so not much different.
It might be cheaper to get parts from Hardy Spicer new then get a shop to make it up, need to suss out the cost of each option really.
Got some new quality Upper front adjustable Camber arms $150
Drivers side window, not scratched - $250
and Delete plug for the rear window - $20
Yep not cheap - sorry
(threw out castor rods, camber arms not to long ago)
    • I clean my wheels every time I was the car, I also clean the barrels, the only product I use on the wheels is truck wash, followed by wash and wax, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, there also great for getting in between the front guards and body, and tight spots in the engine bay ย
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.ย  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
    • Is this not just about people wrecking, and storing, multiple cars in their front yard? I now a tow truck driver that was contracted by the council to clean up housing commission front and rear yards in houses and unit car parks I'm all for working on, and doing maintenance on your car in your garage or driveway, but some people definitely take the pissย  There's one house locally to me that I walk past regularly where the front yard and driveway looks like a wreckers, multiple cars in various stages of being stripped, and the yard looks like all of fluids are basically dumped on the ground I may be wrong, but it seems that the initial reports, which I've seen nothing actually official about yet, may be getting taken out of context, like alot of the latest "the sky is falling" stuff found on the youtubes for clicks
    • have they? Link appreciated. I live in Casey. I can see both sides of the argument in this case. There's a lot of sketchy stuff going on. There needs to be a clear definition of what this is supposed to be IMO. I wager the intent was to be a broad sweeping brush against people who have 4 cars up on blocks on their front lawn, not someone who services their own car behind their own gate on a weekend bothering probably nobody. But it'd be hard to legislate the difference there.
    • Oh, the wheels were already off. I wouldn't normally take them off to clean them although it does make it easier with the ceramic, so I might take them off when reapplying. I don't drive much but now with the ceramic coat, when I do drive and they get dirty I can get most off with the pressure washer. I'll be switching to dirtier pads soon which was the motivation for the ceramic as I usually just clean them and sometimes use Autoglym wheel protector. Nah, f**k the barrels! Haha, I'll give them a quick scrub when they're off the car and a pressure wash, but even I draw the line with the barrels. Yes, dark coloured wheels allow you to get away with a lot! ย
ร—
ร—
