Jimmy - check this for rear camber/caster with newish bushes mate. http://www.skylinesaustralia.com/forums/topic/427828-fs;-blitz-dual-sbc-spec-r-r32-camber-and-castor-arms-and-tyres/
Hey guys,
I am looking for a set of standard R32 GTR castor rods, Rear camber arms, R32 GTR drivers side window and a plug for where the rear windscreen wiper sits
Thanks
FOR $40 DOLLARS - BARGAIN !
Edited by Sinista32
  • 3 weeks later...
Can help on boot carpet. 4pk440's Woodstock
Fairly sure I threw all the trim bits out earlier this year. but will check just in case.
Looking for r32 boot carpet and spare wheel cover, also any other boot trim would be great.
Anyone have a spare set of r32 baby restraints I can buy / borrow for roadworthy?
Also anyone have stock/ quiet r32 gtr exhaust? Apparently my 3 inch super dragger is too loud LOL.
And is my interior chassis supposed to be the same color as my body panels?
Mines black inside....
  • Like 1
If the ones in the 4 door are the same you can borrow mine... I also have a 5Zigen exhaust to suit the gtr but no idea if it's legal.
Afaik all r32 is the same except you would have an extra point in the middle instead of just 2 behind the speakers. Where are you located?
Give me a text on 0410371188
Thanks bro :)
I have a spare mount, its a universal one that came with a seat. I just drilled my parcel shelf and put one there.
Approved spot checked by people who do this for a living. And big washer underneath.
Your chassis should be the same colour.
Maybe panels have been sprayed on outside, maybe smash repair.
The only way to tell is start pulling it apart, and look. Pull out all carpet and seats to see if theres any damage repair etc, theres a thread on it, "what to look for when buying a skyline"
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
