Thinking of going to a return flow intercooler and getting rid of that ugly pipe over the engine and replacing the fan with a non trimmed down one.
What I am chasing is the stock intercooler pipe that goes into the crossover pipe as mine came with a front mount I never had that bit.
Yeah that's what I want to do. I could mount my washer bottle normally if i did too. Plus it looks a lot more stock and moving to melbourne next year I know they are a lot stricter with modifications than they are here and I want to avoid any unwanted attention.
Return Flow ---->> http://www.justjap.com/store/product.php?productid=19402&cat=&page=1
Same side ---->> http://www.justjap.com/store/product.php?productid=16948&cat=&page=1
Take your pick. I'm sorta thinking Same Side. :yes:
I will check for to see if this pipe is in my posession.
I like the return flow a little more. Don't know why, i think i find the return flow has better aesthetics.
I think it will bring better chi to my foronto bumpu.
I am fairly sure 33's and 34's use the same pipes going down into the guard.
WHY ARE ALL NIPPLES DIFFERENT?
All nipples are created equal, some are just more equal than others. :P
33 cooler pipe nips provide pressure to the Actuator but 34 pipe nip sends pressure to the Steering Pump and the Actuator pressure comes straight off a Nip on the Turbo.
Nipped in the Bud. :D
only my old faded ones, they look terrible.
I got these, they must be for gtr as i had to bend a little bit of the metal behind to fit. easy.
http://www.ebay.com.au/itm/R32-GTS-T-SKYLINE-CRYSTAL-CORNER-INDICATORS-CLEAR-LENS-NI1-707-FREE-SHIPPING-/281185971666?pt=AU_Car_Parts_Accessories&hash=item4177fd6dd2
But they had orange ones, cant find em now, maybe they ran out.
The little brackets behind the indicators have broken, and the whole unit is being held in with zip ties. I only really need the back black part, if I can pull the orange part off the existing indicators.
It seems the car has had a front ender at some point, the bit on the rad support that the headlight bolts too is cracked and not really supporting much. Plus the front bumper looks like ass, and is all out of alignment.
sounds just like my car, had to make a front reo, new headlights etc...
much better now but still a bit off with alignment of everything.
Ok so you want my old ones to swap bits, ummm... $40?
Did you buy my old R32?
If your in West Lakes in South Australia, then yes I did.
Yeah sounds good, Ill send a PM
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
