Anyone got a driver's side wing mirror for an r31 skyline? It's an aus-delivered Executive Model, if that makes a difference (it is electric so with electrical connectors would be awesome).
Mine's black but don't really care about the colour ( i suspect they weren't paint coded).
Hit me up on
zero four one 5 838 seven 9 zero if you can help!
Cheers
Andrew
Edit: Also chasing split-fold boot carpet, but that's less of a priority
Edited by dorifticon
I'm looking for a spoiler led brake light for an r33.
Desperado.
Got one. For those that are playing at home, the S1 to S2 rear spoiler LED is different (although they look similar). The sedan S2 is the same as the S2 coupe.
Also, these things tend to let go all the time. Took 3 different ones from a local place to find one that worked! :wacko:
looking to buy an R34 GTT, seeing whats around at the moment, within the range of 10-15K
Have a chat to 'Sinista32' in this forum, they don't come much better than his 34 and it's in your price range .. trust me
:yes:
Edited by THE34T
  • Like 1
Thank you'se ^
Just so there is no surprises it is a Sports Tiptronic, very well maintained and cared for.
It is very clean and the Turbo has been recently replaced with a high flowed OP6 (GT2871), runs 245rwkws.
with supporting equipment (Nistune, injectors, 460lph walbro etc..) plus Gold volk 18" GTC's.
  • Like 1
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
