Anyone got a driver's side wing mirror for an r31 skyline? It's an aus-delivered Executive Model, if that makes a difference (it is electric so with electrical connectors would be awesome).
Mine's black but don't really care about the colour ( i suspect they weren't paint coded).
Hit me up on
zero four one 5 838 seven 9 zero if you can help!
Cheers
Andrew
Edit: Also chasing split-fold boot carpet, but that's less of a priority
Edited by dorifticon
I'm looking for a spoiler led brake light for an r33.
Desperado.
Got one. For those that are playing at home, the S1 to S2 rear spoiler LED is different (although they look similar). The sedan S2 is the same as the S2 coupe.
Also, these things tend to let go all the time. Took 3 different ones from a local place to find one that worked! :wacko:
looking to buy an R34 GTT, seeing whats around at the moment, within the range of 10-15K
Have a chat to 'Sinista32' in this forum, they don't come much better than his 34 and it's in your price range .. trust me
:yes:
Edited by THE34T
  • Like 1
Thank you'se ^
Just so there is no surprises it is a Sports Tiptronic, very well maintained and cared for.
It is very clean and the Turbo has been recently replaced with a high flowed OP6 (GT2871), runs 245rwkws.
with supporting equipment (Nistune, injectors, 460lph walbro etc..) plus Gold volk 18" GTC's.
  • Like 1
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
