A.c.t. Want To Buy Thread
Easy place to start is jack up the front end, turn steering wheel lock to lock and see if any air bubbles purge. If nothing happens it's probably time to pull the pump and inspect. It could also be a line is clogged for whatever reason and you need to isolate the part of the system that is blocked on the high pressure side causing the pump to be unhappy. -
qld plates “GTR R34” for sale $5500 (listed else where)
