Need an engine crane so i can change the mounts.
Anyone want to sell hire or lend one?
Also does anyone have a good solution for rear harness mounts?
A good harness bar or a way of mounting eye bolts in the right spot.
Yes, seen the plates. They are in cams regs and all the people that sell harnesses have them.
Parcel shelf is strong enough?
Ok. That will be easy then.
Anyone got pics of the install? Pretty please, so i can DIY with confidence it will pass scrutineering.
Mainly the parcel shelf, the floorpan ones will be easy.
Also im getting a sparco seat and a bolt in seat base to be able to remove and install when i want to go to track day.
When it shows up ill see how well the base fits and put up some pics.
Hi, long shot, But does anyone have any Nismo 400R rear and front bars for an R33 Series 2? Recently bought the car, former owner has completely wrecked the front bar and the rear one is pretty disgusting. Really like the look of the nismo kit though.
If not would anyone have any other cheapish kits for sale? KR4 Silver preferred, not essential.
Hey guys,
I'm looking for a place to do a single piece tail shaft (or maybe modify my stock 2 piece shaft) in Canberra.
I've talked to M&A Engineering and they quoted ~$800 for a single piece tail shaft which seems hugely expensive.
Is there anywhere else, or time for a trip to Sydney?
Cheers.
There's a place in Sydney who will make a 1piece shaft using the r33 front / s14 rear shafts I have now for $260.
So far, for a completely new shaft with rebuildable uni's etc it's around $700, so not much different.
It might be cheaper to get parts from Hardy Spicer new then get a shop to make it up, need to suss out the cost of each option really.
Got some new quality Upper front adjustable Camber arms $150
Drivers side window, not scratched - $250
and Delete plug for the rear window - $20
Yep not cheap - sorry
(threw out castor rods, camber arms not to long ago)
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
