A.c.t. Want To Buy Thread
And that's great, perfect for your USDM and ADM fuel. The off boost area of the map is defined very well, when compared to other manufacturers. -
By thejacksta88 · Posted
So guys I'm thinking I'll go 6boost manifold gt35-900 50mm waste gate full exhaust Haltech platinum pro Walbro 255 do I need to upgrade coil packs and would anyone suggest drop in cams ? -
I know it'll run, but from what I've seen the Haltech base map is actually quite a bit more conservative than the OEM stock map. -
They have to machine the tunnel with the arp studs in because they change the clearance compared to the factory bolts
By Desean Strickland · Posted
Thanks for the response. I get why line boring the block could cause issues with a spline drive oil pump but I’m just using an extended flat drive collar, u reccon it could still cause issues?
