Where to get Skyline Serviced
So far so good.
Johnny has called and let me know of the current status.
I stuck around there for a little this morning just chatting to the guys (while waiting for a lift to work). They are friendly and seem genuinely interested in looking after you and your business.
Thumbs UP!
  • 1 month later...
Im booked in for Rego and servicing at Trojan today.
I called them yesterday. Johnny answered, he sounds good and sounded more than willing to help me out.
I'll see how it goes.
Question: Where are trojan? i checked the yellow pages and couldn't find them listed.
As said above, Trojan are at:
Unit 2, 45 Heffernan Street
Mitchell
ACT 2911
Phone: 02 6242 6277
Fax: 02 6242 6233
Email: [email protected]
Have had a few mates go through them with great results, I will be taking my car to either them or Ed @ Integra for servicing etc.
Awesome. i'll be giving them a call soon. I'm having boost/misfire problems with the stagea and i've got my bother's skyline in town with major electrics problems too. I'd go to Ed, but mitchell is closer at the moment
Boost Missfire problems around 4000rpm. i put the stock solenoid back in, and now it has a massive spaz when i boost, then i don't get any boost, i think it opens the wastegate totally and doesn't let any pressure build up. anywho, we'll see what someone who knows about cars says.
I'll be coming in on Thursday with the Stagea and Friday with the Skyline. too many cars with dodgy RB25DET's.... wish they'd just work
Last time I was at Jakes, he didn't have a dyno, he used the business next door's, they had an in floor 2wd one [from memory].
Can't remember their business name, it was the shop right next door and immediately towards the city side.
I need to:
Install a Tomei adjustable cam gear, belts and water pump.
Set up my new power FC.
I thought of Jake's [and was happy with his work] but wasn't sure if he was familiar with the gear, I'd go to him again if he 'had the knowledge' so to speak. Otherwise Trojans may be it?
PS I'd consider Ed if he had a Dyno.
Ed has access to multiple dynos including Autotech in Fyshwick.
If you want a dyno tune, tell him and you shall recieve it :P Most people stick to street tune as its cheaper and works effectively for what most people want. He has no problem doing the tunes on a dyno though.
Id confidently say he would be the most knowledgeable and experienced with the Power FC in Canberra (come on, tell me at least one other tuner who has tuned a GTR using a D-Jetro (AFM'less) version of the PFC in Canberra? :D)
EDIT: I also forgot to mention, he is the only one in Canberra with the Datalogit laptop software, and he has the genuine Apexi laptop software on its way from Japan. Means he can do much nicer tunes than simply using the hand controller.
Edited by Amaru
Got a couple of "shout outs" after a few alterations to my car
*John and the boys at Tyrepower Tuggeranong 62934411 for the alignment and other little jobs
*Jake at Jake's Perfomance 62554545 Stockist for Rocket Ind.
*Race Brakes (syd) (02) 96091101 good prices on good pads
*Tony at Just Jap (syd) www.justjap.com (02) 95450532 good prices and great service
*The bloke at Morwood Motors/BBS fyshwick for good advice
**And a big thumbs down to ACT Brakes Mitchell**
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
