Where to get Skyline Serviced
Alternatively give Competition Friction a call. They don't do RB74's but they do have some other pads. They're an AP Racing supplier and I've bought stuff from them before, they're really good. Can probably get you something worth buying.
I don't have their number but whitepages.com.au is your friend.
Gave John a call at Competition Friction, he recommended the Ferodo Racing DS2500 pads. They fit them to OEM HSV's and what not (you know, the boaty whale things...) so they will be adequate for road use (and occasional track use).
~$238 front's, $209 rears - but he did mention that i could probably swap to a cheaper rear option as the fronts do indeed do most of the braking work.
They are located in Murrambatemen apparently, but can organise to get the stuff to Canberra.
Yeah sorry I forgot to mention that they're in Murrambateman.
Last time I bought AP fluid from them I bought it over the phone at 3pm and they couriered it to my place by 6pm for $9.00.
  • 4 weeks later...
Hi All Just wondering if theres anyone good in tuggeranong to get a service done? Since I work in Tuggeranong and it would work out well for me? Would Gas Tune be a good bet?
thx
chris
I use Gas Tune for my regular servicing. I've never had a problem with them and they've always been helpful.
NuggetGTR also uses them and I've seen a Stagea in there too.
I also use gas tune.
got my new clutch put in there last week.
ill need to book in for a tune sometime soon as well
Mate! How much did you pay for the installation of your clutch. Mine is due to change and would like to know the price? BTW, where is gas tune located?
Cheers!
Cheers!
Gas Tune is in the same set of shops as AudioTech on Scollay Street, Greenway -next to car lovers. Dave runs the shop.
A new clutch installed has previously cost me $900.
Cheers
Edited by Sinista32
  • 1 month later...
Have to give thumbs up to Marc at Discount Tyres Belconnen, had the car breakdown at the start of the week. Fitted me in, fixed the problem, reasonable charge, and explained exactly what the problem was and how it was fixed.
Edited by CeJay
Just wanting to confirm that Ed is still at Integra??????????
now owning a R33 (stock!) was considering going to a mechanic that actually knows about them (current mechanic is good but doesnt do any skylines normally).
Based on the feedback, and the fact Integra is close by it sounds like the place to go.
My understanding is that Ed is no longer at Integra. He may show up at AutoTech next year.
Local
Trojan is rated by many on here as good with Skylines.
Peter at Autotech (Fyshwick) for tuning is one of the better ones around at the moment.
Interstate
Croydons (CRD) in Sydney.
As far as going to Integra :rofl: at your own peril.
From a soarer perspective, Trojan rate very highly in my books. AutoTech dyno tuned her last year, which was a great tune; however, he told us he is cautious and wouldn't run anymore than 15psi unless 600cc injecters were fitted. As a result of the dyno shootout at Jakes Performance, I will be going there to get some tweaking done. For normal servicing/problems though, I go to Neil Griffiths at Rush Imports in Queanbeyan, as he is the soarer/toyota guru of probably the whole of Canberra. Despite my previous 'loyalty' to EVO Motorsport; they lost me when Stu forgot what spark plugs to use in the soarer when he did a minor service awhile ago. Rush wasn't open so he asked EVO and the ones they recommended were totally wrong and left her running rather rough until Neil fixed it.
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
