Probs best to keep that stuff to PMs, don't want to be upsetting anyone that could read the forums (and the local workshops do).
xfixiate I have this kit used which I'd let go for $150 if that helps you at all: http://www.nengun.com/apexi/power-intake-gtr
Yeah I'm not going write any more, but I think it's reasonably to just say "bad experience". Not saying it's typical or anything but mine didn't go well :)
LOL your sig threw me. I know this story :D
  • 7 months later...
  • 1 month later...
  • 2 months later...
id recommend TROJAN great customer service and a good bloke...
and for the alarm I have a mongoose m80 :
Features :
FEATURES:
  • Triple circuit automatic engine immobilisation
  • Protects bonnet, boot and all doors
  • Battery back-up siren
  • 2 stage impact sensor
  • Microphone glass break sensor
  • 2 x 3 button water resistant remote controls
  • Silent arm/disarm by remote
  • Sensor disable by remote
  • 'Panic' by remote
  • Car finder by remote
  • Chirp and indicator confirmation of arming status
  • Built-in turbo timer - programmable on/off and 1 to 5 min'
  • Blue dashboard LED
  • LED trigger and open circuit diagnostics
  • 4 digit PIN code override
  • Programme your own PIN code to a number you will not forget !
  • Standards black wiring and concealed main plug
  • Built-in central locking relays
  • 2 stage unlock (optional connection)
  • Boot release (optional)
  • Dome light supervision (optional connection)
  • 12 programmable features
  • 5 year product warranty
that was fitted by BDL before I got it and im very happy with the alarm !
Edited by ..::R33GTS-T::..
haha yea ;) I have a greedy turbo timer under the headunit so I don't have to worry about fing with the settings,, it suchs tho when im not thinking ill leave the keys inside and jack up the car and the alarm goes off,, I don't think the neighbour likes it having a new born and my alarm going off... mind you some people hate me having a nice car on my ls and go to fark with it at night and the alarm goes off the second they touch it.. im so happy the money has been spent on a quality alarm !
Anyone got any recommendations to get an immoblizer/alarm fitted around fyshwick/south side?
Audio tech tuggeranong have been known not to solder and terminator correctly i would go to BDL fyshwick. I am an electronics tech and worked with a few blokes who worked at BDL prior and still recommend going there.
Anyone have any recommendations on auto electricians on the north side? Previously used spence auto electrics, but havent been there for ages. My power windows don't work at all at the moment. Which sucks when it's stuck in the down position.
  • Like 1
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
