urrrr.... sorrry
ok i know this question has been asked before but i just need to clarify...
me and a mechanic mate are rebuilding my engine, and putting on a new turbo. Seems the most popular choise is an HKS 2530... i want to be getting around the 230-250RWKW mark out of it. What exactly will i need to run this turbo? As far as i'm aware it will bolt straight? Can i use an s-afc or do i need something like a power FC? obviously injectors need to be upgraded, but do i need a new fuel pump? I want it to be reliable and so i'd rather do everything properly.
finally, what sort of money would i be looking at?
any help would be greatly appreciated...
https://www.sau.com.au/forums/topic/41528-help-with-turbo/#findComment-851603
Heaps of people going down the 2530/2535 path of late.
You'll definately need to upgrade the fuel pump look at Bosch replacement, as far as injectors go you'll be right on the limit the stock ones if aiming for 230-250rwkw, so If you've got the cash definately go for bigger injectors. If you go injectors then your gunna need a PFC, as the stock ECU will freak with bigger injectors and a Z32 AFM attached
2nd hand 2530 <$2000
2nd hand PFC/BC/HC <$1600
Injectors <$1000
Z32 <$400
Bosch pump <$400
https://www.sau.com.au/forums/topic/41528-help-with-turbo/#findComment-851835
This is being quote from Sydneykid:
http://www.skylinesaustralia.com/forums/sh...ight=power+rwkw
Read 2nd post, exactly what you are after. just choose a turbo basically. either highflowed or hks2503 (yes 2530 is direct bolt on) not sure if anything else needs to be adjusted (ie oil/water lines)
https://www.sau.com.au/forums/topic/41528-help-with-turbo/#findComment-851845
im summary
gtr fuel pump (or equivalent)
gtr intercooler (or equivalent)
twin plate clutch (or equivalent)
boost contoller (or power fc boost kit)
full exhaust, hiflow cat, front pipe and dump pipe
z32 air flow meter (or perhaps even q45)
powerfc
tomei cams (or hks etc.. equivalent)
standard air box with hiflow panel filter (no pod in engine bay)
bigger turbo
either highflowed stock one or hks2530 or ax53b70 (possibility?)
the rest of stock parts and untouched engine should do 250rwkw fine
all up including fitting and tuning is around 10k
https://www.sau.com.au/forums/topic/41528-help-with-turbo/#findComment-851848
Mate you need a stand alone ECU once u start boosting over the 200rwkw stage...i wouldnt recommend a piggy back ecu such as safc or emanage.
Have to change fuel maps, timing, air flow etc..
Dont buy a pggyback system...waste of money...
i recommend u purchase a powerfc or microtech , autronic etc something around those types
+ you have to upgrade your injectors if your trying to achieve 250rwkw
Basically what the guys said above u have to do...
https://www.sau.com.au/forums/topic/41528-help-with-turbo/#findComment-851866
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
