I'm having a problem with my r33 gtst was running fine then I installed 750cc injectors, 044 external pump, walbro 255 intank, microtech lt16c plug and play, removed all the idle control off the manifold, eboost 2 and now the car won't turn off if I turn the key off or even take it out the car will still run then if I stall the engine the reds are still on the only way to get them off is to unplug the computer the car has an alarm but doesn't work (well I can't work the stupid thing) and it also had a hks turbo timer. my plan is to remove the alarm and turbo timer and see what happens. or could it be a fult with the computer it's brand new so ill ring the bloke I got it off tomorrow just wanted to see if anyone can help thanks
https://www.sau.com.au/forums/topic/415328-need-help-car-wont-turn-off/
id be thinking the turbo timer first..
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
    • I'm always a glass half full kinda guy. This will be a great project and the finished product will be awesome.
    • A local that insisted he learned from the best in Australia for RB builds managed to machine a head past the point of saving according to another shop and it dropped a valve too. Ghosted the customer and as far as I know nothing really happened to him. A coworker also recently told a story about owning a Porsche in Germany and running into issues with a dealer tech leaving scratches, oil stains, and missing parts all over his car. I'm not a master tech by any means but at this point I've seen enough expensive mistakes that I'd rather make them myself.
    • 12 months on the pump would be great! The pump is really not that old, I have a receipt from when it was purchased new and it's done ~25,000km since then. it really should be okay. And if it it's not, well. I figured I'd at least run it out as it's already tapped for the nissan temp sensor sticking out of it. Here it was, ready to make it's journey back into the bay, though the balancer had to be tightened/seated more. And it was very stubborn to sit back. So much so that the crank bolt ended up stripping inside the crank instead of the balancer moving to it's intended location.
    • There are professional butt-monkeys too. Just from lack of familiarity in Europe and the US there are plenty of mechanics who do things the wrong way on RBs. Even here in Oz, where we've been playing with RBs since 1986, there are still examples of the not-quite-bright-enough mechanic doing the wrong thing and causing simple jobs to go wrong.
