So I recently installed an Power FC into my 1996 R33 GTR V-Spec, works like a dream. I was driving it home from the tuners and started to get a little load in the wet, it was normal so I kept on going. The next day when I went to reverse the car there was a ton load in the transfer case and the front Torque gauge was sitting on 30!
So put the car up on stands and sure enough the car was locked in 4wd. When I disconnected the pump at the connector and bled the actuator at the back of the transfer, it allowed the front wheels to turn on their own, so transfer case and hydraulics work. The cylinder also moved fine.
So summary is that the ATTESA system will pressurise, causing the transfer case to engage, but will not depressurise, causing it to stay locked in 4wd. There was no warning light on the dash. Bleeding the system causes the transfer case to disengage.
I have done some searching and ruled out the following:
The tires and wheels are the same diameter with similar wear.
The system is pressurising so the pump is fine.
I checked the plugs that connect the pump to the loom and they were fine, no corrosion.
Transfer case is working, so haven't cooked the clutch pack.
Any solutions or if anyone else has had this problem please let me know.
Thanks
Shaun
https://www.sau.com.au/forums/topic/415377-help-r33-gtr-v-spec-locked-in-4wd/
yeah if TPS wires have been change with Power FC install?? then the Attessa could be getting the opposite signal ie. full throttle when there is no throttle and vise versa, have had this and they are the symptoms...ask installer if this is the case
  • 8 years later...
Thanks
Shaun
Did you ever figure out what the issue of was?! I’m currently having like symptoms where I’m locked as soon as I start the engine. 24hrs later the front wheels are free until I start the engine again (pump primes). I bought the car with power FC but now running Haltech 2500 elite with plug and play. Just looking to see what you were able to find out before I pull my hair out.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
