So I recently installed an Power FC into my 1996 R33 GTR V-Spec, works like a dream. I was driving it home from the tuners and started to get a little load in the wet, it was normal so I kept on going. The next day when I went to reverse the car there was a ton load in the transfer case and the front Torque gauge was sitting on 30!
So put the car up on stands and sure enough the car was locked in 4wd. When I disconnected the pump at the connector and bled the actuator at the back of the transfer, it allowed the front wheels to turn on their own, so transfer case and hydraulics work. The cylinder also moved fine.
So summary is that the ATTESA system will pressurise, causing the transfer case to engage, but will not depressurise, causing it to stay locked in 4wd. There was no warning light on the dash. Bleeding the system causes the transfer case to disengage.
I have done some searching and ruled out the following:
The tires and wheels are the same diameter with similar wear.
The system is pressurising so the pump is fine.
I checked the plugs that connect the pump to the loom and they were fine, no corrosion.
Transfer case is working, so haven't cooked the clutch pack.
Any solutions or if anyone else has had this problem please let me know.
Thanks
Shaun
https://www.sau.com.au/forums/topic/415377-help-r33-gtr-v-spec-locked-in-4wd/
yeah if TPS wires have been change with Power FC install?? then the Attessa could be getting the opposite signal ie. full throttle when there is no throttle and vise versa, have had this and they are the symptoms...ask installer if this is the case
  • 8 years later...
Thanks
Shaun
Did you ever figure out what the issue of was?! I’m currently having like symptoms where I’m locked as soon as I start the engine. 24hrs later the front wheels are free until I start the engine again (pump primes). I bought the car with power FC but now running Haltech 2500 elite with plug and play. Just looking to see what you were able to find out before I pull my hair out.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
